Canon ir 2520
I can ping but can not print.when print job is sent the printer blinks and makes some noise but does not print
SOURCE: Canon Printer model IR 3300 making noise while printer
Clean rollers of debris
Posted on Jun 28, 2007
SOURCE: Printer won't print
Printer doesn't print, just feeds the label.
Check your Labels and Ribbon, ensure you have the right ones.
If you have the right ones, here's what you try.
Hit the "setup/exit" button once. Then hit the "+" button repeatedly until you get to Print Meth. It will say Thermal Transfer. That setting can be changed by hitting the select button and the + button. Change it to Direct Thermal Transfer. Then use the setup/exit button to Temporary save the changes. You can change it back to Thermal Transfer doing the same method.
You will get an error, because the ribbon is in. But you can see it it prints.
Try going to the manufacturer website and read the manual about the printer.
If the printer feeds ribbon and doesn't print, more then likely it's a print head problem. When I mean it doesn't print, I mean from the printer control panel without the computer connected.
If you cannot figure out how to print the internal print fonts or setup from the Zebra 4m+ printer, you again need to go to the manufacturers website and read the manual.
Did a little research, appears that I can get a rebuilt print head for about $400. Instructions to install should be with the print head, if not reverse engineering.
Posted on May 12, 2008
  • 79 Answers
SOURCE: Printhead (R), Check Printhead - Canon IPF5000
first of all print a nozzlle check....then see all the color patterns.
The second you can do is to update the firmware to the latest version.
But i think that you have to replace the print head.
Posted on Apr 16, 2009
SOURCE: Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Posted on Oct 16, 2009
SOURCE: Canon IR C3100n copier "NG 853" error
I too tried the UFRv1.42_Win2k-XP-2003_INF Driver for the Canon C3100 and it worked superbly .
Posted on Mar 31, 2010
Canon ir 2520 hang or display sowing canon
hi. maybe there is a problem with the system booting section . try to perform a firmware upgrade
Feb 10, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How to memory clear canon ir 2520
if this is a printer , go to control panel on the pc, click on printers and devices, click on printer and open up the see what is printing tab
clear all in the que
Nov 04, 2015 | Canon Office Equipment & Supplies
Hull, my canon IR 2520 cant print when i send the job it only beeps with a red light, can some one help me...
press the status monitor on touch screen. it will show that load paper LTR. that was an error.
go to additional function-> printer settings-> paper size over ride-> make it ON.
Sep 22, 2015 | Canon Office Equipment & Supplies
PRINT PROBLEM
Well do you have the correct driver from canon u.s.a.? When you say print problem do you mean quality of the print or you can't print to the machine. If quality is the issue probably drum unit. If its a printing issue check the IP address and ping machines ip
Jan 29, 2015 | Canon imageRUNNER 2520 Laser Multifunction...
Error 0099 canon image runner
0099 : SMART PANEL Canon-IR-2520-2525-2530: A memory communication reservation has been cancelled.
Looks like it was answered here for a different printer -
http://www.fixya.com/support/t7156967-canon_ir2020i_dasnt_print_error_code
Sep 09, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
CANON IR2520 SHOWING ERROR CODE 804
In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
Dec 28, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cannon ir2020i photocopies and would
On canon official site you will find link for software download it is on.
May 20, 2010 | Canon iR 2020i Laser Printer
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Sep 17, 2007 | Canon imageRunner C3100 Copier
jasbo
jasbo
