Question about KitchenAid "KHHC2090sss Microwave Hood Combination / 30"""
Kitchenaid microwave error codes
Ps5 error code
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 08, 2008
  • 254 Answers
SOURCE: kitchenaids microwave error message F2.Q1. What to
F2.Q1 Not reading keypad
inputs
1. Unplug microwave oven or disconnect power.
2. Replace the user interface board (UIB).
3. Replace the door control assembly.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
Many of the error codes may be solved by power cycling: unplug microwave oven or
disconnect power. After one minute, plug in microwave oven or reconnect power.
i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
Posted on Feb 14, 2010
  • 949 Answers
SOURCE: my kitchenaid microwave
I have the same model in my home only mine is black rather than stainless. The problem you are encountering is most likely due to a fuse that has blown internally in the unit. Before having it looked at be sure you have power to the wall outlet that the microwave is plugged into. The outlet is usually in the cabinet above the microwave, simply unplug the microwave and plug a lamp or other appliance to verify it is 'live'. If the outlet is live the repair for the fuse may be a done from the front if you have a bit of patients and basic knowledge of electricity. I would recomment calling a service company to make all repairs on this paticular unit as it can be very tricky. Let me know I can help further.
Posted on Apr 18, 2010
  • 794 Answers
SOURCE: Kitchenaid microwave runs for a few seconds and
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 07, 2011
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
Hope this helps.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaids microwave error message F2.Q1. What to
inputs
Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Mar 01, 2009 | KitchenAid Microwave Convection Oven
Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Error Code
F7 problems are usually caused by poor connections. I suggest to unplug the ribbon connector off the control board and cleaned the copper connectors using alcohol or with a pencil eraser. If that does not work the touch pad may be defective.
Jan 19, 2008 | KitchenAid KHHS179L Convection/Microwave...
KitchenAid "KHHC2090sss Microwave Hood Combination / 30""" Logo
144 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
