Question about LG 32" 32LH20R Multi-System HDTV LCD TV FOR 110-220 VOLTS
Loud bang tv
Hello, I heard a loud blast from my 32LH20R LG TV and now it won't come on. Also no standby light. I'm very sad because this the only TV I have got. Please respond as soon as you can. Thanks
circuitcity
  • 137 Answers
SOURCE: lg 50px4d pdp tv
This is a very common problem with model. This problem is your Z sus Board. NOT your power supply, or Y sus board. There is a pair of Diode that goes bad. Your only solution is to change your Z sus Board. Part Number 6871QZH036B average cost $237.00
Best regards
Circuitcity
Posted on Dec 09, 2007
  • 5 Answers
SOURCE: LG LCD 37'' standby problem
if you want i will buy the tv from you
Posted on Feb 23, 2009
  • 4 Answers
SOURCE: LG 50inch Plasma received loud sound then went black
My friend's LG 50" plasma tv has the same problem and it cannot light up. The picture and sound are working fine. But the brightness is too low. It is purchased 2006 too and out of warranty. So I opeend up and found 9 capacitors 3300uF 10V on the power module at the middle of TV are popped. I am planing to replace all of them. They are available at digikey.com. I think this model's power module has design flaw. The cap rating may to low. 10V? Stay tune to see what happen after I change the all the caps.
Posted on Feb 21, 2010
SOURCE: loud pop...LG Model 50PQ30-UA Standby light blinks on/off
this **** dont mother ******* work **** ALL YALL HOES how u like that
Posted on Sep 20, 2010
eagle338
  • 4889 Answers
SOURCE: lg model 42pm4m plasma monitor won't turn on, red
Does the tv make a clicking noise like its trying to turn on before the tv goes into standby and the LED starts flashing? I suspect this is due to a shorted component, most likely to be in the 5V(switching) line and just want to be a bit certain before we start testing the power supply.
Posted on Jul 31, 2011
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
Lg 42 plasma - loud bang/spark smelly smoke and small flame inside.
It is a short circuit caused by some components and/or power capacitors. This may need assessment by a qualified service technician.
Jul 30, 2012 | LG 42PG60 42 in. HD-Ready Plasma TV
I have a Sony KD-34XBR960 and the standby light blinks twice and makes a click noise and a bang sounds off in the back of the TV and then it repeats its self , the TV does not turn on .
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
    Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
    Pull up older posts. You can get all details.
    Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page.
    Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
Jun 02, 2012 | Sony FD Trinitron KD-34XBR960 34" TV
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
I've had several power cuts lately , now my tv is
Hello rogerstanila,
if you have tried unplugging it for a while and if there is still no change then it could be your main board. Unfortunately to fix this could be costly. See if you can find a repair tech that will do a diagnosis for free. But there has quite a bit of problem LG tv's being stuck on standby especially the LCD tv's, Other than this there is not much you can, maybe changing the battery of the remote and just keep trying to click on and off. If it is plugged into a cable box, try unplugging all of that for a while. Leaving it unplugged for a day won't hurt. If nothing else then it could be your main board. You could replace it but as I said before it could you couple hundred dollars. Hope this some what helps.
-Joe
Aug 30, 2011 | LG Televison & Video
Hello, My tv is about 5yrs old.We heard a loud
You need to replace Y main board & buffer, which will cost you around $600-700. Since the TV is five years it will be better to go with new, and it won't be worth enough to spend $700 for old TV.
Hope this helps.
Shane
Feb 13, 2011 | LG 42PX5D 42 in. Plasma HDTV
Loud bang, then audio only from my tv
YES YOUR YSUS PANNEL HAS JUST POPPED CHECK OUT EBAY FOR REPLACEMENT,,
6871QYH053B
IS THE MODEL BOARD U REQUIRE,,
THERE WAS A GUY ON EBAY 64.99 AND 12£ POSTAGE AS LONG AS YOU STILL HAVE SOUND AND NO PICTURE,, YOUR PSU SHOULD BE FINE,,
Feb 11, 2010 | LG 42PX5D 42 in. Plasma HDTV
I heard a loud pop then tv screen went black, now
hi friend,,,,,,,
i think due to high voltage resistor in dma board has blasted,,,,,
did u see any burnt marks,,,,,,,,,reply me
thank u,,,,,,,,
May 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
LG 32" 32LH20R Multi-System HDTV LCD TV FOR 110-220 VOLTS Logo
18 people viewed this question
