Question about Saws
Tire fault procedure used to determine the faults
  • Jack Faire May 20, 2013
    Typo error: The site is bandsawblog.com .
    Sergeant:
  • 468 Answers
Just try visiting bandsawblogs.com . They have lots of informative blogs about band saw. Hope that helps.
Posted on May 20, 2013
Location of central junction box 2008 mariner
Doesn't have a CJB , has SJB - smart junction box . Computer with fuse box in one .
Removal
NOTE: Prior to removal of the SJB, it is necessary to upload module configuration information to a scan tool.
NOTE: The tire pressure monitoring system (TPMS) functionality is integral to the SJB.
NOTE: A new SJB module is delivered in manufacturing mode with pre-set DTCs. These DTCs require that the TPMS sensor training procedure be carried out in order for the DTCs to be cleared. The pre-set DTCs are as follows:
  • B2868 - Left Front Tire Pressure Sensor Fault
  • B2869 - Right Front Tire Pressure Sensor Fault
  • B2870 - Right Rear Tire Pressure Sensor Fault
  • B2871 - Left Rear Tire Pressure Sensor Fault
  • C2780 - ECU in Manufacturer Sub-State
  1. Upload the module configuration information from the SJB. For additional information, refer to Section 418-01 .
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the floor console SJB cover.
  1. Remove the transmission selector lever bezel from the floor console finish panel.
  1. Apply the parking brake.
  1. Remove the parking brake lever boot from the floor console finish panel.
  1. Remove the floor console finish panel.
  1. Remove the SJB screw.
  1. Disconnect the electrical connectors and remove the SJB.
Apr 17, 2018 | Mercury Mariner Cars & Trucks
ESP/ASR INACTIVE ON 2014 BEETLE. ALSO, EPC LIGHT IS ON ALONG WITH ENGINE EMISSION MALFUNCTION AND TIRE PRESSURE WARNING LIGHT.2014 BEETLE 1.8 TURBO TWO DOOR.
These are all separate issues:
Tire pressure monitor because of incorrect tire pressure.
Have the vehicle scanned to determine fault codes for the EPC and emission faults.
Nov 08, 2017 | Volkswagen Beetle Cars & Trucks
How do I fix catalytic converter fault and antipollution fault?
You must run tests to determine if the converter is bad, or if you have some other issue. Use a vacuum gauge to determine if exhaust is restricted.
Apr 27, 2016 | Cars & Trucks
I have audi Q5 2010 model i have a fault code to the transmission i dont know what is this P1f68
HI,
Strongly suggest taking to the dealer as it should still be under warranty.
Code info I googled:
OBD II Fault Code P1F68 :Description of OBD II Fault code P1F68
TH2TNK Sensor Value Offset Shifting
Possible failuer of OBD II Fault code P1F68
  • Hydrogen Tank Internal Temperature Sensor (TH2TNK) offset shifting
  • Inlet Air Temperature Sensor (TA) offset shifting
  • Offset shifting of both Teperature Sensor (TH2TNK) and Inlet Air Temperature Sensor (TA) in Hydrogen Tank
  • RTC function error (Miscalculated Soak Time)
  • FSVSCM failure
  • FCCM failure
Diagnostic Procedure using AutoHex auto Scan tool tester
  • The rear average wheel speed > 15km/h and vehicle speed on the meter<1km/h
  • If the rear average wheel speed > 15km/h and VSP<1km/h lasts for 0.3 seconds, the malfunction is determined.
Test Conditions using AutoHex Scan tool tester
  • Vehicle speed / wheel speed is normal
  • Brake is out of action
  • The automatic brake is out of action
Clear Fault codes Conditions
MIL Status
  • Glow ON
Note:
  • AutoHex is a professional OBD /OBD II diagnostic scanner / scan tool tester.
  • This fault code is a GERENRIC fault code, some cars may change the meaning of this fault code.
    To get the accurate fault code description you may use AutoHex OBD scanner
Oct 24, 2012 | 2010 Audi Q5
ETS light and engine light on somtimes
The ETS if for your Traction Control System. The Engine light is for your Powertrain Control system. Sometimes, a fault in one system can cause BOTH lights to come on or there could be separate faults in each system. The only way to find out is to scan your onboard computer network for fault codes. You must access BOTH the Powertrain Control Module (PCM) and the Electronic Brake Control Module (EBCM) to gather information from each of these systems to locate the cause of the lights illuminating. Once fault codes are retrieved, then the appropriate service procedure must be determined to pinpoint the actual CAUSE of the problem.
PLEASE NOTE: This cannot be performed by using a generic OBD code reader (including those that many of the parts stores use as sales tools to sell you a bunch of parts you don't need).
Jan 30, 2012 | 1995 Pontiac Grand Am
Left front Tire Pressure Low Warning , Tire Pressure Good Scroll Though Menu and Indication on Dash reads 1 psi is it the wheel sensor or does the sysytem have a nother fault or require recalibrated
Have you rotated tire positions? Anyway, if all tires seem to be physically stable, give it a few more runs and another mileage. The 1 psi reading should increase and improve significantly. If not, it is best to have your tires recalibrated, from there you can easily determine if that sensor is at fault or not.
Dec 27, 2010 | 2007 Chevrolet Tahoe
Engine light with wrench and tire came on
{: ) An engine light with wrench indicate a fault in the engine and requires immediate servicing. You should have your vehicle scanned to determine the cause. For your tire light, check first all your tires for proper specifications and recommended pressures. If tires are okay, then they may need to be relearned by a scan tool. I hope the trouble doesn't reach your tire sensors or module. Goodluck.
Dec 14, 2010 | 2008 Chevrolet Trailblazer
Tire sensor fault on our 2006 Ford Explorer after new tires
2006 Ford Truck Explorer
NOTE: The tire pressure sensor training prcedure must be done in an area without radio frequency (RF) noise. RF noise is generated by electrical motor and appliance operation, cell phones, and remote transmitters.
1. Turn the ignition switch to the OFF position
2. Turn the ignition switch to the RUN position three times, ending in the RUN position. Do not wait more than two minutes between each key cycle.
3. Press and release the brake pedal
4. Turn the ignition switch to the OFF position.
Sequence:
1- Left Front Tire
2- Right Front Tire
3- Right Rear Tire
4- Left Rear Tire
5. Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. Do not wait for more than two minutes between each key cycle.
6. The horn will sound once and the TPMS indicator will flash if train mode has been entered successfully. If equipped, the message center displays "TRAIN LEFT FRONT TIRE." Place the magnet on the valve stem of the LF tire pressure sensor. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the TPMS module.
7.Within two minutes after the horn sounds, place the magnet on the valve stem of the RF tire pressure sensor. NOTE: If the TPMS module does not recognize any one of the four tire pressure sensors during the tire training procedure, the horn will sound twice and the message center (if equipped) will display "TIRE TRAINING MODE INCOMPLETE." If this occurs, the entire procedure must be repeated from Step 1.
8. Repeat Step 7 for the RR and LR tires. When the tire training procedure is complete, the horn will sound once and the message center (if equipped) will display TIRE TRAINING MODE COMPLETE.
This should help. For now, probably all Fords are like this. And I do not believe that Ford puts sensors in their spares (some GMs do).
Good luck
Nov 13, 2009 | 2006 Ford Explorer
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
