Question about Onkyo TX-SV414Pro Receiver
Hookups Have: an old Onkyo TX-SV414pro A/V tuner amp Toshibo siungle DVD Onkyo R1 6 disc changer IPOD old Mitsubishi tv just moved and trying to get everything to work! Just the basics and TV to tuner!
  • cohener Aug 13, 2007
    perfect as usual. Thanks
    President:
  • 1,114 Answers
You can download the manual from the link below: http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=TXSV414PROom.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 12, 2007
  • Greg Cann
    Greg Cann Aug 13, 2007
    Thanks for the feedback, it's much appreciated.
    Please would you rate / vote the answer as solved.
    Best regards...
SOURCE:
Where can I get the schematic diagram for this unit? The tuner portion works, both channels of the power amp do not
Service manuals are not available on the net for these. They are suplied to service centers only (as far as I know). These are straightforward units however and should be relatively easy to repair. Are you experienced in audio repair? If so, first check the output transistors. I would suspect that one pair are shorted (at least).
Does the standby light come on? Does the unit attempt to turn on and then shutdown (protect mode)?
Dan
Apr 21, 2010 | Onkyo TX-SV414Pro Receiver
How to connect av receiver to dvd player and hdtv
You can go to the manual at the link below and follow the directions
Links
Aug 17, 2008 | Onkyo TX-SR501 Receiver
Need Onkyo schematic diagram for TX-SV414PRO Tuner / Amp
hi...
try
www.stereomanuals.com
Rate my help if this helps
Thanks
Apr 20, 2010 | Audio Players & Recorders
Onkyo tuner
the model is at the back panel it usually starts with a TX or a T. go to onkyousa.com or call 1-800-229-1887 were here to help.
Oct 29, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SV414Pro
setting the stations goes like this:
First hit class a, b, c etc, and to clear out what is there, hit 1, then hit both memory and the one next to it at the same time to delete what is in there, To program, hit memory, then quickly, class a, b, c, etc. What it does it store that station in the NEXT AVAILABLE slot, so it is best to clear all slots, and have the station call numbers ready in the order you wish to set them.
Jun 15, 2008 | Onkyo TX-SV414Pro Receiver
Onkyo TX-SV414Pro Display Language
Onkyo.com
has the owners manual in full.
Mar 17, 2008 | Onkyo TX-SV414Pro Receiver
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
224 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
