Question about Car Audio & Video
Usb port USB port not charging iPhone. - Car Audio & Video
  • 23 Answers
Reinstall the device driver software.
Posted on May 10, 2013
3 Suggested Answers
  • 12 Answers
SOURCE: When connecting iphone in usb
ANSWER:
The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON:
The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer.
Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION:
You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck!
- Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Posted on Jul 28, 2011
kenw392
  • 2226 Answers
SOURCE: USB port is shorting out. becoming really touchy whenever i plug the usb cable for the iphone in.
It sounds like the solder connections from the port to the board are loose. The leads probably need to be resoldered to the board. You need to be fairly good at soldering to do this repair as the leads from the port are quite small.
Posted on Feb 22, 2012
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Iphone 5 charging and connection problems
You need to figure out the amperage of the usb port in the Veracruz, the dealer should have access to that. If the port isn't putting out more than 500ma the iPhone may fail to charge. I recommend a charger atleast 1amp or higher. You either need to connect using bluetooth to the audio system or a hard wired aux cable to the input of the veracruz.
Nov 27, 2012 | Hyundai 2012 Veracruz Limited
Usb ports not recognizing pen drive, external drive, ipods or iphones but 2 out of 3 usb ports will charge the ipod and iphone. please help!! I've tried unplugging, removing battery, device manager says...
Generally USB ports are part of the motherboard so you will not be able to replace just the USB ports. you can try to uninstall the USB controllers in device manager then reboot your computer. they should automatically get reinstalled. also try booting to safemode and check if it will recognize your USB devices.
*if you get a pop up for found new hardware when you plug in any of your USB devices then it would usually indicate that the hardware is working fine and the problem is with your OS
Mar 31, 2011 | Sony VAIO VGN-FW285J/H Laptop
My iphone is not detected in my laptop i use windows i am able to charge it through the AC adapted but iphone is not detected in my laptop please help
I am not sure that what cause that problem, but we could check where problem comes and fix it. Please ensure that you are using the correct USB cable to connect to laptop. There is an USB cable just use for charging, don't use that cable to connect to laptop.
Also if you use correct USB cable, could you change to another USB port, to check your USB port on laptop.
Do you have Itunes on your laptops? Iphone works with Itunes.
Hope this will help.
Feb 07, 2011 | Apple iPhone Smartphone
IPhone Smartphone: my iphone wont charge...
If you've tried numerou?s USB ports, USB cables as well as wall chargers and it's stil not charging then it's sither a comm port/ribbon cable or battery fault. Neither is expensive to repair. For part pricing and guidescheck ifixit.com but better to send it to an authorised repair centre as they'll locate the exact problem.
May 16, 2010 | Apple iPhone Smartphone
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
Iphone usb not recognize and not charging
Try plugging it into the wall, if it charges when being plugged into the wall, then it is a problem with the USB port on your computer.
Try updating the usb ports on your computer or reinstalling itunes.
Trying different ports and different cables may also help.
Sep 21, 2009 | Apple iPhone Smartphone
IPHONE WON'T CHARGE!!!
the thing in the port is the actuall conductor.
Jul 16, 2009 | Apple iPhone Smartphone
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
