Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I get my carburator to get gas - Craftsman 42 in. Deck 19.5hp Lawn Tractor
  • Craftsman Master
  • 2,478 Answers
Be sure the wire on bottom of carb, is plug in and switch turn on,
Posted on Jun 25, 2013
My Kawasaki 650 sr 1978, wont start,is gas problem because,I start on the bike and in 5 seconds turn off,carburator are clean gas valve has 2 gas out let looking just 1 out let sended gas to the...
arnt the one the vacuum pipe, between the carburator and the sleeve barrel is n nipel were the vacuum pipe must come one it sucks the and open the valve to let the caburator so it can get petrol just see maby im wrong
Feb 01, 2015 | kawasaki Motorcycles
Steelcraft generator 3300 watt Gas tank shut off
The floater of the carburator is bad(Needle). its leaking gas at the carburator and the gas is coming inside the engine at piston intake valves.
Replace carburator needle that stops the intake of gas at the Carburator.
Sep 02, 2014 | Electrical Supplies
Outboard troubleshooting. I have a 75 hp Mercury with 2 carbuerators. Serial # 6559142 it's around a 1989 model.. Problem= tank bubble pumps up tight...sits for a minute and gets soft...when I pump it up...
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Mar 18, 2017 | Boating
Gas shooting out of rubber hose above carburator. craftsman lt200 with kohler engine.
If hose coming off carburator does not connect to anything then it is the over flow for carburator when float gets stuck and does not close needle valve causing excess fuel in carburator bowl and is drained automatically through vent orfice connected to hose that gas is dripping from. If this is the case then remove carburator bowl, check float, needle valve and o-ring in where needle valve goes. sometimes when carburators sit over winter with gas in them the gas breaks down and over time will gel/harden and cause float to hang up and o-ring for needle valve to deteriate and not sealing properly. clean and replace parts as nessesary.
I hope this helped.
Oct 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas flows from cutoff valve to carburator hose connection but does not flow into carburator. What is blocking the flow?
On the top of the carburator there is a needle valve, closed by the float lever.
If the carburator chamber is full with gas, the valve is closed and no more gas can enter the chamber.
If the chamber is empty and no gas flows inside, the valve may be stuck in closed position. Cleaning or some sharp (but not very hard) knoks on chamber cover may help.
Some times the float gets broken and falls down. This is a bigger damage, because it may lead to carburator overflow.
Jul 19, 2010 | Coleman Powermate Premium Plus 6250W...
Change gas filter
is this a Carburator motor or a fuel injection system...if carburator them the fuel filter will be at the end of the gas line going in to the carburator..if it is a fuel injection systam then it should be on drivers side some where in front of the rear wheel along side the frame will look like a bell
Mar 04, 2010 | 1987 GMC Suburban
Scott's Lawnmower/after using all the gas in the carburator...
Check the fuel inlet, and make sure that the 'feed' is ok.
You might want to change/flush the fuel filter.
Have fun ;)
If problems still persist, you know where to come.
Jul 31, 2009 | Garden
Gas peculating in carburator and running into motor.
there is exhaust that runs from head to head under carburetor . there should be a damper that opens when cold and closes when hot . when it stays open after motor reaches operating temperature gas in bowl boils and gas is a vapor instead of a mist and causes motor to run lean .
Apr 17, 2009 | 1988 Ford Thunderbird
Carburator
To my knowledge, the gas tank vent does not hook up to the carburator, it is just a means of escape for trapped air inside the gas tank, so normally it is just left hanging.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | 1979 Pontiac Firebird
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
