Question about KitchenAid KFRU368VSS Propane Grill
Kitchen aide outdoor grill is buzzing
After a heavy storm it started to make a buzzing noise and the only way to stop it was to unplug it. The gas burner does not get gas either now. How do i repair it?
    Top Expert:
  • KitchenAid Master
  • 42,771 Answers
Her is water in the ignite module and shorting out ( noise) Replace units that suffered wet damage.
Posted on Jun 14, 2013
2 Suggested Answers
  • 4736 Answers
SOURCE: the thin mesh top
It's supposed to stop large pieces of debris from getting on the heat plaques. You can probably just replace the mesh top, if the screws that hold it on aren't to rusted. Appliance Factory Parts is about the best place to find the part, if it is available. http://www.appliancefactoryparts.com/gasgrillparts/brands/kitchenaid/
Good luck and Happy Grilling!!
Posted on Jul 03, 2011
I have a kitchen aid over the range microwave that makes a humming noise ehen off. Almost sounds like a buzzing transformer. ykhms1850ss-0 Is the model.
Possibly the wall receptacle has been wired with black and white wires reversed and/or the green ground wire not connected.
I had a GE microwave that periodically would buzz white operating but eventually the buzzing stopped.
Sep 16, 2016 | Microwave Ovens
Why does my electric range makes abuzzing noise every few minute
How do I find out the cause of a low frequency hum in my ...
answers.angieslist.com > Home > Other
May 6, 2013 - Can hear it a bit outdoors in the back of my house. ... Edit Answer (for another -17 minute) ... floor in each room of the house - water sourced noise goes a long ways, ... 8) - gas control valve or electric control box on a gas furnace, or its ... These will commonly make a hum or wheeze sound, for only for a few ...
Induction unit makes buzzing sound - Seasoned Advice
cooking.stackexchange.com/.../induction-unit-makes-buzzing-sound
Mar 1, 2011 - But my accidental activation rate is still well above acceptable on all ... So if the buzz is normal for induction cooking today, why did they ... gas ranges vs induction ranges with some notes on which pans worked ... A good service and re- positioning of the fans on their axles always clears my noise problems.
Dec 29, 2015 | Kitchen Ranges
Kitchenaid outdoor gas grill gas not flowing
Make sure the gas knob on the propane tank is turn on. If it is on, then the gas regulator is defective,
Oct 30, 2015 | KitchenAid Kitchen Ranges
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
Is this yellow flame on my grill ok?
Clean out burner holes on all the burners they look blocked , then adjust air mix to burners could need more air to burn
Jul 23, 2012 | KitchenAid KBGS364PSS Grill
The thin mesh top on my sear burner on my kitchen aid outdoor gas grill is torn and rotted. Do i have to replace whole sear burner? I'm guessing it stops juices from penetrating through to the heat...
Jul 03, 2011 | KitchenAid KBSU367TSS Gas All-in-One Grill...
I have a dacor bbq in an island. Today we had very heavy rain. With that said, the lighter was on and making the typical clicking noises. I made sure that the gas was not on. Finally, I turned on the...
The really odd thing about this, is one shouldn't affect the other. So, I suspect that some moisture got into the ignitor button or module during the heavy rain and is causing the ignitor to button/switch to make contact when it shouldn't. Dismantle the ignitor button, remove the battery and check for moisture. Even if you don't see any, use a Q Tip lightly sprayed with WD40 to clean the interior. The WD40 will dissipate any moisture and help to lubricate the contacts.Then check all the wiring from the module to the burner ignitors to make sure they are not grounding out on something that the wires shouldn't be touching.
Hope this helps to solve your problem.
Mar 21, 2011 | Dacor 52'' Builtin Outdoor Grill Cover...
Need to take off oven door to tighten handle, gas range Kitchen aid free standing,30inch
open door 1/2 way to the first spring stop (used in broiling position) lift door straight up from the position be careful this is a heavy item
Dec 13, 2009 | KitchenAid KESC307 Electric Kitchen Range
TIMER IS BUZZING NON STOP.
how old is the oven? does it have a analog clock? If it does then turn the stop time clock and the buzzing should stop.
Oct 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
KitchenAid KFRU368VSS Propane Grill Logo
74 people viewed this question
Top KitchenAid Grilling Experts
paulcarew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
