Question about ASUS M2N-MX Motherboard
Replaced motherboard & pc won't power up
Recently I recieved an error message that "cpu failed test". I replaced motherboard, cpu etc. When I hooked everything up again there was no response when power supply turned on. Green light on motherboard comes on, but when I press on/off switch....nothing. No fans..nothing. Any suggestions?
  • 1 more comment
  • lotl0371 Mar 23, 2009
    Thanks for reply. Followed instructions...still no response when on/off switch pressed.
  • Thomas F. Schneider May 11, 2010
    Have you tried substituting another power supply? Just a thought. New MB and new CPU right? Also try using the other piece of Ram instead of the ne yuou are currently using. It should be in the slot closes to the CPU.
    Take the MB  out. Unhook everything except one strip of Ram and the PS and case wires. See if it will boot now.
Yours memory card(Ram) may not suitable to your motherboard, read the instruction manual of motherboard, what ram is suitable for your motherboard.
Posted on Jun 20, 2009
SOURCE:
Motherboard replacement
Kind of a major deal since all cards and drives need to be unplugged, the old MB pulled, a new one (with CPU) inserted and all cards, drives, etc hooked up again. Before you do this look at the age and condition of auxillaries. Often it is time to upgrade power supply, hard drives, etc. You may be better off with a new system. Try www.directron.com They sell MB with CPU (tested) or complete systems
Feb 18, 2015 | Computers & Internet
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
Replacement motherboard not rebooting
If you did not change the CPU the the BIOS is not seeing it correctly. You can update the BIOS or you should be able to press F1 to continue to boot.
Apr 09, 2014 | Dell Studio 17 (1749) Laptop black -...
1 long beep 2 short beeps
Hello Hardyjosef,
Below is the beep code chart for the mini 10 systems.
No POST
If the system does not perform a Power-On Self-Test, there are various things to look for:
1.Check that the system has a power light.
2.If the system has no power light, ensure it is plugged into AC power. Remove the battery.
3.If the system has power but is not performing a POST, Check for one of the following Beep code errors.
Beep Code Description Failure Coverage
1 BIOS ROM checksum in progress or failure. BIOS Chip Motherboard Failure or ROM Error
2 No RAM Detected No Memory Detected
3 Chipset Error (North and South Bridge Chipset, DMA/IMR/Timer Error for Intel platform); Chipset Error Motherboard Failure
Time-Of-Day Clock test failure.
Gate A20 Failure
Super I/O Chip Failure
Keyboard Controller Test Failure
4 RAM Read/Write Failure Memory Failure
5 RTC Power Fail. COMS Battery Failure
6 Video BIOS Test Failure Video Card Failure
7 CPU Cache test failure CPU Failure
8 LCD LCD Failure
4.With the power off and the system unplugged, remove all CRUs from the system and reconnect the AC adapter to the system and try again.
Try reseatting the memory to see if that will resolve the issue. If not, the motherboard may be bad and will need to be replaced. If you need another motherboard you can call the Dell Spare Parts Department at 1-877-717-3355 to purchase one.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jun 25, 2013 | Dell Inspiron Mini 10 Notebook
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Check the CPU fan or BIOS settings for proper fan speed.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Mark
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Sep 10, 2009 | Gateway T-1625 Notebook
Working SG-72 MOBOs failing 1 by 1, no POST after BSOD, just fans
test the cpus in other machines. if your not getting any boot or beeps, then it is the bios or cpu.
Jun 30, 2009 | Abit SG-72 Motherboard
Home built 4 yr old pc wont boot
You have voice message telling you CPU test failed , but does it BEEP at all ? if you have a Beep code then replace the CPU fan ( when CPU gets too hot it will either shut down or the PC will not boot up at all )
Jul 23, 2008 | Intel Motherboard
Desktop Power Light Pulses
Try removing all PCI/AGP and RAM cards from the motherboard and disconnecting all drives via their power and ribbon cables too and see if you at least get the boot process to start. if not, that confirms your motherboard is bad.
If it does start but gives errors for the missing components, start putting them back in or connecting them back up one at a time until the problem returns and then you have your failed part.
Jul 11, 2008 | Computers & Internet
System Restart regularly
Sounds to me like your power supply may be failing or loose connections.
You don't mention if you're overclocking the CPU. Double-check the BIOS settings to make sure things are set properly.
Another thing to check is if the CPU is overheating. Make sure the heat sink is still firmly attached to the CPU and that the CPU fan is operating.
Dec 07, 2007 | ASUS A8N-VM Motherboard
ASUS M2N-MX Motherboard Logo
176 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
