Question about Refrigerators
Mobitronic mps 50a
With the battery voltage down to 12.5 and the WAECO Fridge tries to start, the voltage out of the MPS 50A falls to around 10.4 which is not enough to get the fridge running. The voltage at the MPS input stays around 12.4, indicating that there is excessive voltage drop through the MPS unit. Alan Wilson alanrwilson2@ozemail.com.au
5 Suggested Answers
miket756
  • 2702 Answers
SOURCE: I have a Chefmate Mini Fridge - BC-50A that does
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
Posted on Nov 19, 2009
SOURCE: waeco cf 40 portable refrigerator runs continuely
This is not an uncommon problem and you're probably experiencing a voltage drop between the battery
Posted on Aug 30, 2010
evanusa
  • 197 Answers
SOURCE: my waeco fridge freezer is
Please provide us with the model code of the freezer.
Posted on Jun 10, 2011
SOURCE: mobitronic mps50A components
Hello Brenden,
Did you find the value for r13 on the Mobitronics MPS-50A power supply?
I am looking for that value also.
I
cannot locate where R13 is on the board so if you give me some direction I may be able to help.
I do not have a diagram just a power supply that I am trying to repair also.
Cheers
Stewart
Sydney
Australia
Posted on Dec 15, 2011
Can Huawei AC to DC Power converter ETP48100-B1-50A model support battery?
Yes, ETP48100-B1-50A is the latest Huawei AC to DC power converter, but it doesn't has battery slots, only Huawei EPS30-4815AF-15A and Huawei EPS30-4815AF-30A can support this function.
More products:
Huawei EPS75-4815AF-45A
Huawei OLT
May 24, 2017 | Huawei Computers & Internet
The light globe in my 140 litre 2door waeco fridge only lasts about 5 to 10 days before it blows again. The globes are 12 v 5 watt genuine waeco globes. How do I fix this?
It could be that the fridge's voltage regulator is putting out a higher voltage, but likely it is something else. Check that nothing is blocking the bulb and causing it to overheat internally limiting its operating life.
Feb 01, 2015 | Miscellaneous
Mobitronic user manuals
Fordern Sie weitere Informationen zur umfangreichen Produktpalette aus dem Hause
WAECO. Bestellen Sie einfach unsere Kataloge kostenlos und unverbindlich unter
der Internetadresse: www.waeco.de
http://www.waeco.com/tmp/900_serie_B_10S_08.pdf
Jul 29, 2012 | GPS
I'm looking for a copy of the circuit diagram for the waeco power supply model mps 50 or mps50a
As this appears NOT to be a flat panel TV you might want to repost it in the major appliance section of this site.
May 17, 2012 | Televison & Video
Mobitronic mps50A components
Hello Brenden,
I
Cheers
Stewart
Sydney
Australia
Nov 13, 2011 | Washing Machines
2000 ford explorer, fuse box don't show me what fuses are for
There are two fuse boxes. A baqttery junction box under the hood on the drivers side and one inside on drivers side. Good luck.
Fuse/Relay
Location
Fuse Amp
Rating
Power Distribution Box
Description
1 60A** I/P Fuse Panel
2 40A** Blower Motor Relay
3 50A** 4 Wheel Anti-Lock Brake System
(4WABS) Module
4 30A** Power Windows, Power Moon
Roof, Power Seat
5 50A** Ignition Switch, Starter Relay
6 20A** Transfer Case Relay
7 - Not Used
8 20A** Air Suspension
9 40A** Air Suspension
10 30A** PCM Power Relay
1 10A* A/C Relay
2 30A* Heated Seats
3 30A* Heated Backlight
4 15A* Fog Lamps and Daytime Running
Lamps
5 4 3 2 1
10 9 8 7 6
12 11 10 9
8 7 6 5
4 3 2 1
15 14 13
2 1 1
9
6
10
8
7
5
175
MEGAFUSE
Roadside emergencies
197
Fuse/Relay
Location
Fuse Amp
Rating
Description
5 - Not Used
6 10A* Powertrain Control Module
7 30A* 4 Wheel Anti-Lock System
(4WABS) Module
8 15A* Rear Wiper Motor
9 20A* Fuel Pump Relay and RAP
Module
10 15A* Horn Relay
11 15A* Parklamps Relay and Mainlight
Switch
12 30A* Mainlight Switch and
Multifunction Switch
13 15A* Heated Oxygen Sensor, EGR
Vacuum Regulator, EVR Solenoid,
Camshaft Position (CMP) Sensor,
Canister Vent Solenoid
14 30A* Generator/Voltage Regulator
15 - Not Used
1 - Wiper Park Relay
2 - A/C Relay
3 - Wiper High/Low Relay
4 - PCM Power Relay
5 - Fuel Pump Relay
6 - Starter Relay
7 - Horn Relay
8 - Rear Wipe Down Relay
9 - Blower Motor Relay
10 - Rear Wipe Up Relay
1 - Not Used
1 - DRL Diode
2 - Electronic Engine Controls Diode
Apr 06, 2011 | 2000 Ford Explorer
Waeco cf 40 portable refrigerator runs continuely
Dec 20, 2009 | Refrigerators
Abs fuse
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump2.gif relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
Oct 29, 2009 | 2003 Ford Explorer
Installing load panel & inlet box
The bigger lugs will tighten just fine. Go that route and it will be easy to upgrade! If it seems way large when you put the wire in, strip the wire back and double it over. The # 6 may be a bit big for the 30 amp lugs. 30 amp circuit is usually # 10.
Sep 08, 2009 | Reliance Controls 50-Amp Power Inlet Box...
Driver down loads
plz visit the lg website and search for it
May 14, 2008 | Motu 2408mk3 Sound Card
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
