Question about Magic Chef CTB1722 Top Freezer Refrigerator
Refrigerator problem everything freezes in fridge compartment. When you turn termostat to 0 it does not stop. Seems like termostat, but your website said could be belt, look in mirror where
  • lidiyamark Aug 12, 2007
    How much termostat cost and how to remove old one. I tried and can not find disconnection hole
  • 291 Answers
The thermostat is only thing that controls temp. in your refrigerator...your right on the money!
Posted on Aug 21, 2007
  • Mike Johnson
    Mike Johnson Aug 21, 2007
    so far havnt found ur model # are u sure its correct?
Hi my fridge freezer isn't cooling or freezing it seems like its trying to go on but then stops again
Hi Gerardine.
The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
or go to this link and have a read up.
Why is my refrigerator not cooling Refrigerator
or this one.
fridge freezer isn cooling or freezing Google Search
Jul 03, 2018 | Refrigerators
Our electrolux rm4230 motorhome fridge seems to be too cold. It is freezing salad stuff even set on 1. Is it the thermostat? Where is the thermostat?
setting on one is equal to 0 C
fridge settings are the lower the number the colder the compartment
try setting it to 4
May 12, 2018 | Electrolux Refrigerators
My Hoover 400 cyclic refrigerator motor won't stop running.
what setting do you have the control knob set to ?
Feb 12, 2015 | Hoover Refrigerators
Refrigerator freezes everything in the refrigerator
Usually, there is a control knob/dial somewhere in the fridge. Did you try turning it to less power?
Nov 18, 2013 | Dometic RM2652 Refrigerator
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Fridge has water in it which freezes into sheets.
see if there is a drain line going up the back if there is you should be able to take if loose to see if its stopped up
Apr 24, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
My mini fridge freezes everything
Need to replace the termostat.
Apr 03, 2009 | Refrigerators
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Magic Chef CTB1722 Top Freezer Refrigerator Logo
191 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
