Question about Friedrich M24DYF 24,000 BTU Dual Zone Wall-Mounted Ductless Split System with Heat Pump, Advanced Inverter Technology and Low Ambient Operation 2 x MW12Y3FM Indoor /MR24DY3F Outdoor
Indoor light flashes 2 time on my friedrich indoor heads
My 2 inside heads both flash the timer light 2 times and rest for about 15 seconds and flash 2 times over and over
3 Suggested Answers
SOURCE: I have a Friedrich Split system model MW18Y3Y w
I'm having the exact same problem, same model. My guess at this point is that the outdoor unit fan has been iced up due to recent heavy snows. I have a shop light hooked up to thaw things out and will re-check in the AM
Posted on Dec 28, 2009
  • 182 Answers
SOURCE: i have a friedrich ductless
not able to find the error codes for the unit number you gave but, here is a number you can call to get them. sorry not more help.
1-866-793-0323 spacer.gif Mon - Fri 9:00am to 6:00pm EST
Posted on Dec 20, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
MY FIJITSU inverter is not working correctly, the timer light is flashing continuously and the timer lights flashes 5 times can anyone help pleawe
fujitsu is a good brand.
try one of these two things:
Turn the unit off then on again. After that press test button on remote control (rear side) and look how many times now operation and timer LED flashes. Note that. Then press MANUAL/AUTO button on indoor unit until you hear 3 beeps from buzzer. That will erase error memory.
Switch off and than on unit and see if indication repeat or it is gone. If it is gone, keep using your unit.
If it is repeated post your notes here.
OR+++++++++++++++++++++FOR OTHER MODELS
5 x Operation flash and a constant Timer flash indicates an outdoor unit control error. With this code flashing on the indoor unit, you need to point the remote at the unit and push the test run button. The flash pattern will change to a continuously flashing Operation light and a number of flashes of the timer light which gives more detail on what the error is.
To get the unit to try to restart you need to push and hold the manual/auto button on the indoor unit for a few seconds then reset the mains power supply but leave it off for a minute or so for the unit to power down completely. If you are going to try this make sure you make a note of any error codes first if you have to get someone out to look at it, it will help them a lot.
Jan 05, 2015 | Inverter Heating & Cooling
Shutting off flash
Yes, but not in the Auto mode, where the camera decides whether or not it needs the flash. Switch to the P mode, which works like Auto except you have control over the flash, exposure, and other factors. See pages 26 and 42 of this manual.
Apr 12, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
My friedrich mw18y3f dosent work any more, the operation light and the timer light flash together 4 times and after it's the timer light that flashes 4 times alone. can someone help me
1( replace batteries with FULL charge and the same type alkalines do not mix
2( clean the contacts batteries very well c.cleaner
3)retight the springs contacts with long pliers for better contacts.
4) open the remote control for to clean the keypad from dirty, oxide, corrosion and bad contacts.
5) proceed to reset the code, and try again.
However if do not work, you must go to the repair shop Tv for fix it.
God bless you
Oct 08, 2012 | Friedrich Heat Pump, 18, 000 BtuH, Wall...
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
I have a Friedrich MW18Y3F unit. It's not heating this morning but the operation light and timer light are flashing together 5 times and then the timer light flashes a 6th time by itself. On line manual...
Try the reset at the unit and see if the fan tries to engage at all. Also check the wiring connections between the indoor and outdoor units. If it does not then you either have a bad fan motor or the control board is bad.
Jan 30, 2011 | Heating & Cooling
I have a friedrich ductless split m# mw24cy3f .. call for cool only fan runs inside, call for heat nothing runs, outdoor temp at the moment is 38 degrees, error code light blinks on indoor unit......
Dec 20, 2010 | Friedrich Heating & Cooling
First Alert Timer ET220
1. Set time: Rotate dial (PM indicated by PM
light) Stop at current time. Press Time set
button.
2. Rotate dial to desired ON time; press & hold
On/off button, rotate dial to OFF time, release
On/off button
3. To Cancel the time.. Press & Hold on/off and
rotate one cycle to erase. and will have to
rest time (1)
Dec 03, 2008 | Hardware & Accessories
Friedrich M24DYF 24,000 BTU Dual Zone Wall-Mounted Ductless Split System with Heat Pump, Advanced Inverter Technology and Low Ambient Operation 2 x MW12Y3FM Indoor /MR24DY3F Outdoor Logo
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
