Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Bottom of projection tube is another color
In the top right hand and bottom left hand corner of the screen the color seems to be distorted. It is most noticable with blues. The color seems to turn a yellowish brown color. Is the projection tube going? If so estimated cost? Is it worth fixing or should I purchase another TV.
    Genius:
  • 1,153 Answers
Yes, worth fixing, sounds like convergence is out on the tip ends. Check papers for Convergence controls. See if have auto fix.
Posted on Aug 15, 2007
SOURCE:
My Hitachi 50UX26B/27K red picture tube seems to be out of line with the blue/green tubes. When I press the magic focus it runs a short 30 second cycle then displays the number 3 in the bottom right hand...
Your convergence is fried go to ebay and order this item number 130475189383 copy n paste and put in ebay search.You will also need a delsolering iron, a soldering iron, some kind of skill soldering and patience.
Jan 18, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
Bottom left corner of my toshiba 65h83 is blurred with color distortion mainly magenta and green. Distortion Is a half moon shape with the open end facing the edge of the set. Total distortion takes up...
Have you tried the "Magic Focus" Button/Option in the Menu Setup Screen? If you have and it still is there, You Have a Burned out Color Tube. It is Cheaper to Throw it away and Buy a New one.
Good Luck..
May 12, 2009 | Toshiba 42H81 42" Rear Projection...
Red color distortion.
You have a Convergence problem. Most likely the STK392-120"s are bad and possibly a few resistors. Not something you should attempt if you've never done one. I would recommend calling a service co. in to repair it.
Apr 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Distorted picture
i was just working on a set with the same problem .. i found a east west correction curicit with a falty transistor. something in that cuircit has failed.
Jan 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
PT-65wx51e 65in
suddenly breaks pink & green colors in bottom left & top right corners with distortion in picture
Dec 09, 2007 | Panasonic PT-65WX51 65" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
