Question about Jandy Ae2500t 115,000 Btu Heat Pump
Low pressure fault - Jandy Ae2500t 115,000 Btu Heat Pump
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Check filters if clean check pressure switch see if 24 volts both sides if not not enough pressure or bad switch
Posted on Sep 25, 2014
ML 320 CDI 2008 Model. Car cuts out while driving, fault code: fuel rail pressure low.
it needs a cat converter to enable the ECM to function properly next low fuel pressure can be from EVAP system not venting the tank properly, failing fuel pump or faulty pressure regulator unloading too much fuel and dropping the pressure
at this point I would be looking at the EVAP system , then the pressure regulator
Nov 06, 2016 | Cars & Trucks
Tip
Komatsu Fault Codes
E02 PC-the EPC system;
E03, Swing parking brake system;
E10, the engine controller power failure, the engine control drive system circuit malfunction (this engine stall;
E11, the engine control system failure (decrease of output power, in order to protect the engine);
E14, the feedback system abnormalities;
E15, engine sensors (temperature, fuel pressure, oil pressure) fault;
EOE, a network failure.
The fault code: the 989L00 the engine controller lock warning (mode 1).
989M00, the engine controller to lock warning (mode 2).
989N00, the engine controller to lock warning (mode 3).
AA10NX air filter clogging.
AB00KE charging voltage is too low.
B @ BAZG, low oil pressure.
B @ BAZK, the oil level is too low.
B @ BCNS, engine coolant overheating.
The @ B BCZK the coolant level is too low.
B @ the HANS, the hydraulic oil from overheating.
CA111, the engine controller internal fault.
CA115, the engine speed sensor and backup speed sensor failure.
CA122, the intake air pressure sensor feedback voltage is too high failure.
CA123, the intake air pressure sensor feedback voltage is too low failure.
CA131, the throttle plate sensor feedback voltage failure.
CA132 throttle plate sensor feedback voltage and low failure.
CA144, high coolant temperature sensor feedback voltage fault 145, the coolant temperature sensor feedback voltage is too low failure;
CA153, intake air temperature sensor feedback voltage is too high failure;
CA154, intake air temperature sensor feedback voltage is too low failure;
CA155, the intake air temperature is too high (over limit);
CA187, sensor power supply voltage is too high failure;
More Fault Codes HERE http://truckmanual.weebly.com/komatsu-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
Tip
?JCB FAULT CODES LIST
P0087 (flashing code 227) shared sump low pressure fault (for pump without pressure supply)
The main fault symptoms
• Engine severe vibration.
• idling unstable
• Output Fall
• exhaust smoke
• It may be too large output
P0088 (flashing code 118) shared the tank pressure is abnormally high (first or second stage)
• idle instability
• Output Fall
• channeling gas engine failure
• exhaust smoke
P0089 (flashing code 151) shared the tank pressure failure (for pump pressure supply is too large)
• idle instability
• Output Fall
• exhaust smoke
P0090 (flashing code 247) SCV drive system open, + B short circuit or shorted to ground
• Depending on the open / short situations, there may be an engine stall and / or launch
Machine channeling gas.
• exhaust smoke
• Output is too large
P0107 (flashing code 71) atmospheric pressure sensor circuit input low (open or shorted to ground)
Due to spare the equivalent altitude 2000 m (6562 ft)
• exhaust smoke at high altitude.
• insufficient output at low altitude
P0108 (flashing code 71) atmospheric pressure sensor circuit input high (+ 5V shorted)
• The high altitude exhaust smoke
• lack of low altitude output
P0112 (flashing code 22) intake air temperature sensor fault (low voltage fault, earth fault, short circuit)
• When cold starting, may exhaust white smoke.
More here http://truckmanual.weebly.com/jcb-fault-codes.html
Oil pressure light staying on when ticking over,or braking
The fault is indicating low oil pressure, when the engine revs are low the oil pressure drops, first thing to do is change the oil pressure switch (cheapest option), see if that cures the fault. If not have the oil pressure checked, if the fault is the oil pump, then it could cause serious engine damage. Needs to be check out as soon as possible. Good Luck
Jan 27, 2014 | Cars & Trucks
Laars pool heater low pressure
pressure switch fault, on inadeqauate flow to pressure switch
Jun 03, 2013 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Fault Low Flo Pressure
check pressure switch and copper tube to it
Nov 04, 2012 | Jandy Air Energy Heat Pump - 100,000 Btus
Cant Find a list of codes 1989 Buick Century. Car stalls and has a rough idle. coads are 31 43 and 44
Here is a code list for you. Remember this doesn't always mena a sensor issue, the problem can be in the wiring as well, or in the case of a lean code you may have an actual lean condition due to a vacuum leak at the intake or vacuum hoses or connections. I have highlighted your fault codes and added extra notes.
GM common codes for OBD1 (for vehicles made before 1995)
12 System normal
13 oxygen sensor circuit open
14 coolant sensor high resistance or shorted
15 coolant sensor circuit low or open
16 direct ignition system (DIS) fault in circuit
17 cam position sensor fault
18 crank or cam sensor error
19 crank sensor circuit fault
21 tps sensor out of range
22 tps sensor signal voltage low
23 intake air temp sensor out of range, low
24 vehicle speed (vss) sensor circuit fault
25 air temp sensor sensor out of range, high
26 quad-driver module (computer) circuit #1 fault
27 quad-driver module (computer) 2nd gear circuit
28 quad-driver module (computer) circuit #2 fault
29 quad driver module (computer) 4th gear circuit
31 camshaft position sensor fault
32 egr circuit fault
33 map sensor signal out of range, high
34 map sensor signal out of range, low
35 idle air control sensor circuit fault
36 ignition system circuit error
38 brake input circuit fault
39 clutch input circuit fault
41 cam sensor circuit fault, igntion control circuit fault
42 electronic spark timing (EST) circuit grounded
43 knock sensor malfunction or electronic spark control (ESC) circuit fault (ignore this for now)
44 oxygen sensor lean exhaust (make sure you no engine vacuum leaks)
45 oxygen sensor rich exhaust
46 pass-key II circuit or ps.pressure switch circuit fault
47 pcm-bcm data circuit
48 misfire diagnosis
51 calibration error, mem-cal, ecm or eeprom failure
52 engine oil temperature circuit, low temperature indicated
53 battery voltage error or egr or pass-key II circuit
54 egr system failure or fuel pump circuit low voltage
55 a/d converter error or pcm not grounded or lean fuel or frounded reference voltage
56 quad-driver module #2 circuit
57 boost control problem
58 vehicle anti-theft system fuel enable circuit
61 a/c system performance or degraded oxygen sensor signal
62 engine oil temperature high temperature indicated
63 oxygen sensor right side circuit open or map sensor out of range
64 oxygen sensor right side lean exhaust indicated
65 oxygen sensor right side rich exhaust indicated
66 a/c pressure sensor circuit low pressure
67 a/c pressure sensor circuit or a/c clutch circuit failure
68 a/c compressor relay circuit failure
69 a/c clutch circuit head pressure high
70 a/c refrigerant pressure circuit high
71 a/c evaporator temperature sensor circuit low
72 gear selector switch circuit
73 a/c evaporator temperature circuit high
75 digital egr #1 solenoid error
76 digital egr #2 solenoid error
77 digital egr #3 solenoid error
79 vehicle speed sensor (vss) circuit signal high
80 vehicle speed sensor (vss) circuit signal low
81 brake input circuit fault
82 ignition control (IC) 3X signal error
85 prom error
86 analog/digital ecm error
87 eeprom error
99 power management
Jul 21, 2011 | 1989 Buick Century
When i pull the code up on my 1992 park avenue it blinks once then blinks twice. what does this code mean?
This is code 12 and it means "System Normal"
Here is the complete list of fault codes for your Buick
12 System normal
31 cam position sensor fault
43 knock sensor
or electronic spark control circuit fault
85 prom error
87 eeprom error
99 power management
May 05, 2011 | Buick Park Avenue Cars & Trucks
Powerstroke 7.3 2000 two fault codes p0603 and p1211 my reader tells me but i have no manual
p1111 System Pass (No DTCs Available)
P0107 BARO Circuit Low Input
P0l08 BARO Circuit High Input
P0112 IAT Sensor Circuit Low Input
P0113 IAT Sensor Circuit High Input
P0122 Accelerator Pedal Sensor Circuit Low Input
P0123 Accelerator Pedal Sensor Circuit High Input
P0197 EOT Sensor Circuit Low Input
P0198 EOT Sensor Circuit High Input
P0220 Throttle Switch B Circuit Malfunction
P0221 Throttle Switch B Circuit Performance
P0230 Fuel Pump Relay Driver Fail
P0231 Fuel Pump Relay Driver Circuit Failure
P0232 Fuel Pump Relay Driver Failed Off
P0236 Turbo Boost Sensor A Circuit Performance
P0237 Turbo Boost Sensor A Circuit Low Input
P0238 Turbo Boost Sensor A Circuit High Input
P0261 Injector Circuit Low - Cylinder 1
P0262 Injector Circuit High - Cylinder 1
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Injector Circuit Low - Cylinder 2
P0265 Injector Circuit High - Cylinder 2
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Injector Circuit Low - Cylinder 3
P0268 Injector Circuit High - Cylinder 3
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Injector Circuit Low - Cylinder 4
P0271 Injector Circuit High - Cylinder 4
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Injector Circuit Low - Cylinder 5
P0274 Injector Circuit High - Cylinder 5
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Injector Circuit Low - Cylinder 6
P0277 Injector Circuit High - Cylinder 6
P0278 Cylinder 6 Contribution/Balance Fault
PO279 Injector Circuit Low - Cylinder 7
P0280 Injector Circuit High - Cylinder 7
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Injector Circuit Low - Cylinder 8
P0283 Injector Circuit High - Cylinder 8
P0284 Cylinder 8 Contribution/Balance Fault
P0301 Fault Cylinder A-Misfire Detected (CYL 1)
P0302 Fault Cylinder B-Misfire Detected (CYL2)
P0303 Fault Cylinder D-Nlisfire Detected (CYL 3)
P0304 Fault Cylinder E-Misfire Detected (CYL 4)
P0305 Fault Cylinder F-Misfire Detected (CYL5)
P0306 Fault Cylinder G-Nlisfire Detected (CYL 6)
P0307 Fault Cylinder C-Misfire Detected (CYL 7)
P0308 Fault Cylinder H-Misfire Detected (CYL 8)
P0340 CMP Sensor Circuit Malfunction
P0341 CMP Sensor Circuit Performance
P0344 CMP Sensor Circuit Intermittent
P0360 Glow Plug Circuit Malfunction
P0381 Glow Plug Indicator Circuit Malfunction
P0460 Fuel Tank Level Indicator Circuit Malfunction
P0470 Exhaust Back Pressure Sensor Circuit Malfunction
P0471 Exhaust Back Pressure Sensor Circuit Performance
P0472 Exhaust Back Pressure Sensor Circuit Low Input
P0473 Exhaust Back Pressure Sensor Circuit High Input
P0476 Exhaust Pressure Control Valve Maffunction
P0476 Exhaust Pressure Control Valve Performance
P0478 Exhaust Pressure Control Valve High Input
P0500 Vehicle Speed Sensor (VSS) Malfunction
P0503 Vehicle Speed Sensor Noisy
PO541 Manifold Intake Air Heater
P0542 Manifold Intake Air Heater
P0560 System Voltage Malfunction
P0662 System Voltage Low
P0563 System Voltage High
P0666 Cruise 'On" Signal Malfunction
P0566 Cruise "Off' Signal Malfunction
P0667 Cruise 'Resume' Signal Malfunction
P0668 Cruise "Set' Signal Malfunction
P0669 Cruise "Coast' Signal Malfunction
P0571 Brake Svdtch A Circuit Malfunction
P0603 Internal Control Module KAM Error
P0605 Internal Control Module ROM Error
PO606 PCM Processor Fault
P0640 Manifold Intake Air Heater
P0670 Glow plug control circuit malfunction
P0671 Glow plug #1 circuit failure
P0672 Glow plug #2 circuit failure
P0673 Glow plug #3 circuit failure
P0674 Glow plug #4 circuit failure
P0675 Glow plug #5 circuit failure
P0676 Glow plug #6 circuit failure
P0677 Glow plug #7 circuit failure
P0678 Glow plug #8 circuit failure
P0683 Glow plug diagnostic signal communication fault
P0703 Brake Switch B Circuit Malfunction
P0704 Clutch Pedal Position Switch Input Circuit Malfunction
P0705 TR Sensor Circuit Malfunction
P0707 TR Sensor Circuit Low Input
P0708 TR Sensor Circuit High Input
P0712 Transmission Fluid Temp. Sensor CKT Low Input
P0713 Transmission Fluid Temp. Sensor CKT High Input
P0715 TSS Sensor Circuit Malfunction Fault
P0717 TSS Intermittent Failure
P0718 Noisy TSS
P0720 OSS Sensor Circuit Malfunction
P0721 Noisy OSS
P0722 OSS Intermittent Failure
P0732 Gear Two Ratio Error
P0733 Gear Three Ratio Error
P0741 TCC Circuit Performance
P0743 Torque Converter Clutch System Electrical Failure
P0750 Shift Solenoid 1 Malfunction
P0755 Shift Solenoid B Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0800 Logon to http://web.archive.org/web/200701120...utoadvice.com/ A.S.A.P
P1000 OBD 11 Monitor Checks Not Complete. More Driving Required
P1105 Dual Alternator Upper Fault (Monitor)
P1106 Dual Afternator Lower Fault (Control)
P1107 Dual Alternator Lower Circuit Malfunction (Control)
P1108 Dual Alternator BATT Lamp Circuit Malfunction
P1118 Manifold Air Temperature Sensor Low Input
P1119 Manifold Air Temperature Sensor High Input
P1139 Water in Fuel Indicator Circuit Malfunction
P1140 Water in Fuel Condition
P1184 Engine Oil Tamp Sensor Circuit Performance
P1209 Injection Control System Pressure Peak Fault
P1210 Injection Control Pressure Above Expected Level
P1211 ICP Not Controllable - Pressure Abow/Below Desired
P1212 ICP Voltage Not at Expected Level
P1218 CID Stuck High
P1219 CID Stuck Low
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastagate Fail Steady State Test
P1250 Electronic Passive Anti-Theft System
P1261 High to Low Side Short - Cylinder 1
P1262 High to Low Side Short - Cylinder 2
P1263 High to Low Side Short - Cylinder 3
P1264 High to Low Side Short - Cylinder 4
P1265 High to Low Side Short - Cylinder 5
P1266 High to Low Side Short - Cylinder 6
P1267 High to Low Side Short - Cylinder 7
P1268 High to Low Side Short - Cylinder 8
P1271 High to Low Side Open - Cylinder 1
P1272 High to Low Side Open - Cylinder 2
P1273 High to Low Side Open - Cylinder 3
P1274 High to Low Side Open - Cylinder 4
P1275 High to Low Side Open - Cylinder 5
P1276 High to Low Side Open - Cylinder 6
P1277 High to Low Side Open - Cylinder 7
P1278 High to Low Side Open - Cylinder 8
P1280 ICP Circuit Out of Range Low
P1281 ICP Circuit Out of Range High
P1282 Excessive ICP
P1263 IPR Circuit Failure
P1284 ICP Failure - Aborts KOER or CCT Test
P1291 High Side No. 1 (Right) Short to GND or B
P1292 High Side No. 2 (Left) Short to GND or B
P1293 High Side Open Bank No. 1 (Right)
P1294 High Side Open Bank No. 2 (Left)
P1295 Multiple Faults on Bank No. 1 (Right)
P1296 Multiple Faults on Bank No. 2 (Left)
P1297 High Sides Shorted Together
P1298 IDM Failure
P1316 Injector Circuit/IDM Codes Detected
P1391 Glow Plug Circuit Low Input Bank No. 1(Right)
P1393 Glow Plug Circuit Low Input Bank No. 2 (Left)
P1395 Glow Plug Monitor Fault Bank No. 1
P1396 Glow Plug Monitor Fault Bank No. 2
P1397 SYstem Voltage Out of Self Test Range
P1464 A/C On During KOER or CCT Test
P1501 VSS Out Of Self Test Range
P1502 Invalid Self Test - APCM Functioning
P1531 Invalid Test -Accelerator Pedal Movement
P1536 Parking Brake Applied Failure
P1662 IDM EN Circuit Failure
P1663 FDCS Circuit Failure
P1667 CID Circuit Failure
P1668 PCM -IDM Diagnostic Communication Error
P1670 EF Feedback Signal Not Detected
P1690 Wastegate Control Valve Malfunction
P1702 TRS Sensor Intermittent Circuit Malfunction
P1704 Digital TRS Failed to Transition State
P1705 TR Sensor out of Self Test Range
P1711 TFT Sensor Out of Self Test Range
P1713 TFT Stuck in Range Low-Below 50'F
P1714 Shilt Solenoid A Inductive Signature Malfunction
P1715 Shift Solenoid B Inductive Signature Malfunction
P1718 TFT Stuck in Range High-Above 25OF
P1728 Transmission Slip Error
P1729 4x4L Switch Error
P1744 Torque Converter Clutch System Performance
P1746 EPC Solenoid Open Circuit
P1747 EPC Solenoid Short Circuit
P1754 CCS (Solenoid) Circuit Malfunction
P1760 EPC Solenoid Short Intermittent
P1780 TCS Circuit Out of self Test Range
P1781 4x4L Circuit Out of Self Test Range
P1783 Transmission Overtemperature Condition
No Code No Communication
No Code Auxiliary Powertrain Control System
No Code Tachometer
Nov 15, 2010 | Ford F-250 Cars & Trucks
I need to know what the code 18 and 41 means for 93 Buick Park Avenue Ultra with a 3.8 litre supercharged eng
When fixing codes start with first code first / it dos not always mean that the sensor is the fault ,it could be in the harness / the plug or the ground. and reference signal should be tested , but in this case you most likely could get away with replacing the cam sensor, that would be the Lest expensive and easiest to start with,to git to it you will have to remove the alternator hope this is help full, the other code suggest that it could be the crank sensor , that and the plug for it does fail quite often but first things first feel free to ask if you should have any further questions , Thank you ,
Mar 31, 2010 | 1993 Buick Park Avenue
Open Questions:
See all Jandy Ae2500t 115,000 Btu Heat Pump Questions
Jandy Ae2500t 115,000 Btu Heat Pump Logo
73 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
