Question about Xerox Office Equipment & Supplies
Xerox error 024/747
User cannot print
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Xerox error codes
error code 377.123.02 for Xerox 6700
Jan 12, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
What does a error code 99,060 mean on a xerox 8570
On the 8570 that is either a wave amp, the print head or a bad or loose cable in between.
Not a problem for the casual user.
I hope it's under warranty.
Sep 27, 2012 | Xerox Qube 8570/DNM Color Laser Printer...
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
135 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
