Your booklet shows that the battery level is displayed on the bottom right of the screen of my new 1033. However, it does not. What do I press to display the battery level?
Well, I tried pressing and HOLDING down the mode button. The battery level display miraculously showed up. I’ve also read (yahoo answers) that battery level display will show up automatically when battery is low. Hopefully I won't have to do this every time I recharge the battery.
Above solution does not actually work. Sorry for the post. It just happened that the battery was low when I tried pressing and holding down the mode button. In fact, the battery level indicator ONLY shows up when the battery is nearly dead. This is a Kodak 1033 design flaw as far as I'm concerned. Can you imagine driving your car without a fuel gauge? That's what it is like using this camera. Sadly, I'm returning this camera for this reason alone.
How to Change the Brightness of the Display
To darken the display, press the yellow 2nd button and then press and hold down the Up-Arrow button located in the upper right section of the keypad. Release the Up-Arrow button when the display has reached the desired level of darkness.
To lighten the display, press the yellow 2nd button and then press and hold down the Down-Arrow button. Release the Down-Arrow button when the display has reached the desired level of lightness.
As you go through this process, a number will appear at the top right corner of the display. If this number is 7 or higher when your screen reaches the desired level of brightness, then your batteries are getting low and may need replacing soon. This number will be approximately 3 or 4 for new batteries.
Same Problem with Kodak M1033. Just bought it. No battery level shown although manual plainly shows that it should be there. Useless. This is going back in the morning.
your booklet shows that the battery level is displayed on the bottom right of the screen of my new 1033. However, it does not. What do I press to display the battery level?
