Question about Sewing Machines
My thread keeps sheering, thinning out and breaking off at the needle when i am sewing
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Mimito7
  • 128 Answers
SOURCE: I'm sewing metallic fabric and the needle keeps
Hi, What you need to get is a bottle of Sewers Aid . It is made by Prym. The best way to use it is, spread an even layer up and down the spool of thread. When that section of thread passes thru the needle it will lubricate to enable the needle to pass thru the fabric with greater ease.
Posted on May 06, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
Why does the thread on my sewing machine keep breaking?
Several possibilities. It could be the needle, the tension too tight, mis-threading, the thread weight, brand, poor quality, or fabric incompatibility with needle & thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
All About Needles
Nov 09, 2016 | Sewing Machines
My needle threads keep on breaking, I don't know what to do
  • Check the tension of the upper thread. If it's too tight, the pressure on the thread will cause it to break.
  • Check the thread you are using. If you're using two different kinds (one on top and one in the bobbin) that difference can cause the threads to break.
  • Are you using the proper thread for the job? Using a thin or light thread for sewing heavy fabric can lead to breakage.
  • Are you using the correct needle? Sewing knits with a sharp needle or sewing woven fabrics with a knit or ballpoint needle can also cause the thread to snap.
  • Is your machine threaded correctly? Incorrect threading can be another cause for thread breakage.
I hope this helps.
Mar 04, 2015 | Sewing Machines
I folded over a terry cloth towel and now my machine isn't working right?
The thread is incorrect for material.
: or incorrect size needle or it is bent.
:Not threaded correctly.
Thread tangled around the spool holder.
: Thread too thick for needle or too thin.
Hope one of these helps.
Feb 10, 2015 | Kenmore Sewing Machines
Have a Janome 1600P-Top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Apr 21, 2013 | Sewing Machines
My machine keeps breaking the thread
Mar 02, 2013 | Sewing Machines
My thread keeps breaking and the bobbin tension is too loose
adjust the top thread tension one number or letter higher at a time
and sew on a scrap piece of fabric till the stitches look normal
The needle thread breaks
Jan 15, 2013 | Sewing Machines
When sewing thread keeps breaking and comes out of the needle
keep longer thread tails before you begin to sew and make sure
the thread tails are pulled behind the needle before you start sewing
Jan 08, 2013 | Yamata Sewing Machines
Thread keeps breaking
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
The top thread keeps breaking. The thread pulls tight and breaks. I have removed a broken thread piece from the upper take-up lever, rethreaded (several times), cleaned out bobbin, moved thread spool on...
try a tension a 3 to 5 on the top tension
try changing to a needle or if it's a new needle make sure the flat side of the needle faces the back of the machine and pushed all the way up into the needle holder
make sure the needle & thread are correct for each other, if the needle is to thin or to heavy for the fabric it will not work
Aug 27, 2011 | Brother InnovIs QC1000 Electronic Sewing...
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
