Samsung wf7708n6w1
Door is closed but machine says its open, could it be a fuse?
sonicboomele
  • 1557 Answers
SOURCE: my samsung washing machine indicates the door is
the door switch is broken or a wire has come off take the switch unit out and check its connected then check it to see that its working if you dont know how to take it to a service shop they should test it for free and tell you if it needs to be replaced then you can order one from your nearest samsung auth repairer.
hope this helps
merry christmas
please rember to rate this advice thanks
Posted on Dec 07, 2010
  • 6277 Answers
SOURCE: Samsung Model WF7708N6W1 Washing Machine, just
The indications are that the door lock is not working or physically broken/misaligned. Alternatively there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor probably requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jun 19, 2011
Testimonial: "Bang On, Great Knowledge, and had already read some of your responses to similar problems earlier so you had helped before helping so.....Great.!!"
  • 6277 Answers
SOURCE: Samsung WF7708N6W1 will not finish cycle -just
(I've pre-typed the following 'cos I cannot type fast!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
John C
Posted on Aug 18, 2011
greg_margo
  • 1959 Answers
SOURCE: my washing machine says door opened even i closed the door it' always says opened
Sounds like a sticky or broken lid switch. Over time, detergent and dirt can settle in and around the switch, causing it to stick or disabling it altogether. Try pushing the switch in manually to see if the door open warning goes out.
Posted on Oct 31, 2011
  • 867 Answers
SOURCE: Sampsung wf7708n6w1 door won't open!
Your door switch/lock is broken, you need to unplug the machine and remove the top, you can then reach down (tight space) and using a small screwdriver you can pry around the switch and get the door to open, you need to get a replacement door switch for the machine.
Leaning the machine back can make it easier to access the switch.
Posted on Mar 06, 2012
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
If its a bearing on the samsung wf7708n6w1 is it repairable
Yes and you can either go on amazon or ebay and get a repair manual or try and find a free downloadable one on the net
Nov 19, 2014 | Washing Machines
Mar 06, 2012 | Samsung Washing Machines
Samsung Model WF7708N6W1 Washing Machine, just beeps and then flashes "door". Will not start wash?? Its always needed to be pushed in a little but now just assumes the door is not closed even...
John C
Jun 19, 2011 | Samsung Washing Machines
Samsung sensor quick P801 can't close the door. The main front door can not be close easily. I take me 6 to 7 try to close it. Sometime I need to slap the door firmly. The Door seem to be close but just...
you should not be able to open or close the door with the washer ON. You must first shut off machine before closing the door, then turn the machine ON, this should lock the door closed. to open the door, you must shut the machine OFF, then the door should open easily. Follow the directions in the manual... you can Download the owners manual here, in your language of choice; Follow the link below. just copy and paste it into you browsers window.
http://www.usersmanualguide.com/samsung/washing_machine__drum_type/p801
Don't forget to rate the answer.
Jan 24, 2011 | Samsung Washing Machines
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
Cleaning a front load washer for mold and mmildew
What's the question?
Use a mild bleach
heres the solution from washing machine manuals, dont know why fuses and powerre included in this...
odor in washer
• Water supply taps are not
open fully.
• Water line hoses are kinked,
pinched, or bent.
• Water inlet filters are clogged.
• Water pressure to tap or
house is too low.
• Power cord is not properly
plugged in.
• House fuse is blown, circuit
breaker has tripped, or power
outage has occurred.
• The door is not closed
properly.
• Incorrect or too much
detergent has been used.
• Inside of tub not cleaned
properly.
• Make sure that the water taps are open fully.
• Make sure the hoses are not kinked or pinched. Be
careful when moving the washer.
• Clean the inlet filters. See the Care and Cleaning
section.
• Check another faucet in the house to make sure that
household water pressure is adequate.
• Make sure that the plug is plugged securely into a
grounded, 3-prong, 120-VAC, 60-Hz. outlet.
• Reset circuit breaker or replace fuse. Do not increase
fuse capacity. If the problem is a circuit overload,
have it corrected by a qualified electrician.
• Make sure that the door is closed properly and press
the START/PAUSE button. After starting a cycle, it
may take a few moments before the drum begins to
turn or spin. The washer will not spin unless the door
is locked (DOOR LOCK will appear in the display).
• If the door is closed and locked and the open door
error message is displayed, call for service.
• Use only HE (High-Efficiency) detergent in accordance with the
manufacturer’s instructions.
• Run the TUB CLEAN cycle regularly. Be sure to wipe around and
under the door seal frequently.
• Clean around door seal/glass to prevent odor or mildew:
1. wipe dry the door seal/glass and the door opening area
2. wipe around the inner drum/door seal and the lower door seal
Aug 20, 2009 | Samsung Washing Machines
Washing Machines Logo
Top Washing Machines Experts
