Question about Mtd Bronco Rear Tine Tiller
Parts diagram where can i find a parts diagram for yard machine rear tine tiller model number 21a-410-372
    Loyalty:
    Visited the website for 30 consecutive days.
  • Mtd Master
  • 1,432 Answers
Try PartsTree.com
Posted on Jan 21, 2018
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
KMusselmann
  • 247 Answers
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
Posted on Apr 17, 2009
  • 376 Answers
SOURCE: 21A412A372 MTD YARD MACHINE TILLER RUNS BUT THE
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Remember to put a dash here.. 21A-412A327
Posted on May 14, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
  • 468 Answers
SOURCE: Yard Machine rear tine 6hp tiller that wont start.
Ok, what's happening, is your carburetor metering hole is plugged. When you place your thumb over the carb, it draws fuel through the primer circuit to feed the engine instead. What you need to do, is clamp off the fuel line, take the nut off the bottom of the carburetor bowl, and clean that nut. Look closely at it; there is a hole that goes down the center of it, and a hole that goes through it side to side towards the bottom. These make a "T" shape inside the nut. You need to make sure that these are completely clear and clean. The one at the bottom is very small, and plugs easily. You usually need a small piece of wire to clean it, such as a single strand from a wire brush. You can use carburetor cleaner to loosen it up a bit, but the important part is to clean that hole out. You also need to make sure that the float moves freely up and down while you're in there. If it sticks in the up position, it will starve fuel as well. Also look closely at the gas that came out when you did this. Was there any water in it? If so, let a bit drain out before putting it all back together.(unclamp the fuel line). Hope you have it back online soon.
Posted on Mar 23, 2010
Testimonial: "Nut was clogged. Now it starts but acts as it is in choke position, dont think there is a choke. Engine reves, falls, reves falls but stays going."
Where can I find tines for yard machine tiller model #21A-410-062
at the tine shop? try a lawn mower repair depo
Jul 06, 2014 | Garden
Belt broke on my 12 inch mtd yard machine front tine tiller model 21a-250m000 how do i replace it. thank you for your help!
part # 754-04123 v-belt 1-888-656-7278 for parts pull off 4 bolt on bottom red cover to frame replace belt put cover back on
Feb 27, 2011 | Mtd Products Yard Machines 158CC Tiller
I'm looking for blades for a tecumseh 5.5 formula, can you guys help me?
Copy and past this into your browser's address bar. Then hit enter! Tecumseh parts galore!
http://www.m-and-d.com/scan/se=TECUMSEH/sf=category/st=db/co=yes/op=eq/sp=brands_results/va=category_name=TECUMSEH/tf=sku/ml=20.html
May 10, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Repair Manual
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh-engine-specs.html......
this is where i go for parts breakdowns and service literature.......hope this helps.!
May 20, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Tecumseh Self Propelled Yard Machine - What size spark plug do I need?
You can download the owners manual for any Tecumseh engine here. You'll have to find the model number on the engine to do so.
http://www.tecumsehpower.com/frameset.php?page=CustomerService/OperatorManuals/index.php
May 09, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
HELP WITH A HUSKEE TILLER #21A-340-131
The pdf manual can be found at mtdproducts.com. You need to know your model and serial number to access the download. Really not that good a manual.
Mar 23, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Mtd Bronco Rear Tine Tiller Logo
53 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
