Question about Mitsubishi WS-55809 55" Rear Projection Television
Blurry and convergence doesn't work
I have a mitsubishi 55 inch HD 1080. The picture is highly distorted on Cable tv (almost showing double) and slightly distorted on DVDs. Even when I set it to default it does not correct itself. When I go into advance settings in the menu i'm only able to change the convergence horizontally and not vertically.
  • 3 more comments
  • Anonymous Nov 19, 2007
    I have same problem....Had It fixed once and seems the problem has come back even worse.
    Each gun color is seperated and you see 3 of every thing on the screen.
  • nana50 Dec 03, 2007
    I have the Mitsubshi Hdtv 2003 model WS-B55
    We have been having trouble with the color red distorted along with a double picture. We've tried to converge manually using the remote and settings but the vertical won't move.Distortion is more on the outsides of the picture.What else can you tell us to do? Thank you Nancy
  • danmj1 Dec 08, 2007
    convergence
  • Donnette Haynes Nov 13, 2008
    I am having the same issue. My picture is pretty much double also. I have tried several times to restore the convergence back to factory settings but the picture will not clear up. Please advise.
  • Anonymous Nov 26, 2008
    I have the same issue with the tv. Tried to restore to factory settings, vertical won't move. Double picture, red outline, blue distortion. Any other ideas?
My blue convergence is out at top and bottom of the TV. Its a Mitsubishi 65in. Help !!!
Posted on Nov 26, 2008
Harley, can you show pictures of these parts so that I know exactly what I'm taking out? there is so much metal in there and I don't want to take the wrong thing out.
Posted on Dec 10, 2007
I had the same problem. here is how i fixed it: Unplug the set.take off the back panel, the big silver metal heat dispersing element has to come out.its about 5" by 6" the two modules are clamped to the back of this part. I had to slide out the whole board.what has caused the problem is the thermal compound has gotten old and has worn out. clean off the old and buy some new compound at any computer store. i got mine at Best Buy. Its not that hard to do. Don't let all the wires freak you out. unplug all of them. they can only go back in the same place they came from. I could go into a lot of detail on how i did this but that's the just of it.
Posted on Dec 07, 2007
  • harleydrag1 Dec 11, 2007
    The heat dispersing element looks kind of like a piece of cori gated metal.its right in the center of the computer board. You cant miss it.You have to slide out the whole board. once you slid out the computer board you will see the two modules clamped to the back of the piece im trying to describe.Im sorry but i cant take any pic's until this weekend.
    Genius:
  • 1,153 Answers
OPTION MENU "MENU 0170" SERVICE MENU "MENU 0157" CONVERGENCE MENU "MENU 0159, 4 FINE, 5 COARSE, 6 MISC
Posted on Aug 17, 2007
SOURCE:
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
What universal remote control is compatible for the mitsubishi 1080 hd series i belive mine is 55 inches? i need to align the red n blue crosses so my picture is not blurry.
ANY mitsubishi remote will work, universal remotes will not do the job.
Is color skewed and or 3 d looking?
The more you tell me the better I can help you.
SD TECH
Sep 15, 2010 | Mitsubishi WS-65315 65" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
Jun 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
231 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
