Question about Hampton Bay 30 In. High Velocity Pedestal Fan in Chrome Finish
Hvp 30 have a part from our free standing fan. Has 2 wires coming from each side. Letters stamped areC61 10uF+and- 5%. 250V.AC 50/60 Hz. max temp 70 degrees C, Tin a S trademark stamp. Backward R U. With E185116 below.
3 Suggested Answers
  • 351 Answers
SOURCE: the ceiling fan spin was slow. The c61 e185116
Hampton Bay is an exclusive brand to Home Depot. They have replacement parts for these fans. They are usually in the lighing / ceiling fan section. The end cap that has fan parts and lighting accessories.
Posted on Jun 23, 2010
canwoodjc
  • 3301 Answers
SOURCE: Where can I get a
save yourself some money and time and take the old one to a radio shack or electronics shop that has a parts dept
Posted on Jul 23, 2011
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Ac smell in 2009 Mercedes c300
Check drain and unclog if required.
Remove air cabin filter (see you tube for instructions). Make sure it is done in a clean place so no dust or dirt gets in while you do this.
Block Air Cabin filter opening with duct tape.
Set fan to 50% (3/4), temperature to minimum
AC must be OFF
Open hood and using a Spray bottle, spray half a bottle of Alcohol 70% into the air intake vents at bottom of windshield
Turn off fan
Let it sit for 30 to 60 min
Set temperature to max and fan to max
Open hood and using a Spray bottle, spray the second half (250ml) of a bottle of Alcohol 70% into the air intake vents at bottom of windshield.
Turn heater and fan OFF
Take off duct tape and replace the air cabin filter (new one is better)
If you don't take off the air cabin filter, a lot of the alcohol or disinfenctant (like Lysol) may be stuck in the filter causing an irritating smell.
Replace Air cabin filter if possible.
Jan 30, 2013 | Mercedes-Benz Cars & Trucks
97 accord lx overheats unless ac is on
If the cooling fans are not coming on when the vehicle is overheating try this.
Look for the coolant temp switch B. it will be located near the thermostat housing on the back side of the passenger side of the engine (follow the lower hose to the engine). It will have a white with green wire and a black wire. Unplug it, turn the key to the run position, the engine does not need to be running. ground the white with green wire. if the fans come on replace the coolant temp switch B sensor.
Sep 18, 2012 | 1997 Honda Accord
Fans wont come on 2004 ford tarus
It sounds like temp control switch, either on radiator or thermostat housing, it will have a couple of wires on it, if you disconnect the plug and just connect the 2 wires together with the ignition on the fans should start, if they do then replace the switch, if they dont check for a blown fuse, ( they are normally quite a high amp fuse)
Jun 16, 2011 | Ford Taurus Cars & Trucks
The AC in my 1992 Honda Accord works. However, it blows hot air when I'm stopped at a light for too long. "Honda diagnosed the problem; said something about some type of thermostat that sticks,...
This indicates that the booster fan for AC has failed. If you look in back of the radiator, you will see 2 electric fans. One is for the engine cooling, and the other is a booster for when the AC is running to provide for extra air flow through radiator and AC condenser. (May also apply when engine overheats, but not sure of that) As car is moving along, then air is pushed through allowing AC to work. When standing still, and fan failed, then no air (or less air) passing over condenser grill. (Condenser is the one in front of the radiator) No cool.
While standing still with engine running, open the hood and look at fans. Watch your fingers. Fans can start at any time. One may be running or not. Now turn on AC and look at fans. Both should come on together. If not, then it may be either the fan, or the fan relay or fuse. Or even the wire.
Does the engine get extra hot while standing still running? Let it sit there for ten mins or so and see if main fan kicks on. Watch your temp gauge, you dont want it to boil over. When the temp reaches the level it is at normally, one fan should kick on. If temp keeps climbing and no fan, then that may be the same issue, likely the main relay.
Jun 01, 2011 | 1992 Honda Accord
Doesnt seem to come on not sure what the problem is there a certain temp that the fan will kick on the car has sit for two yrs and just now getting it up and running
Check the temp sensor on side of radiator. It's a large brass fitting with a couple of wires coming from it. To test, get car/truck up to normal operating temp and turn AC on. AC usually triggers fan to come on. Others try bypassing sensor with leads or leads to fan directly from battery but you "chance" damaging fan. The part is called "aux fan sensor"
Mar 03, 2011 | Chevrolet Cavalier Cars & Trucks
What is the parts of a monitor
Part Number:RK284AA#ABA
* Display Type LCD display / TFT active matrix
* Built-in Devices Microphone , Speakers
* Width 20.6 in
* Depth 11.4 in
* Height 18.9 in
* Weight 19.8 lbs
* Enclosure Color ( The image of the product displayed may be of a different color )
* Localization English / United States
* Display (projector) image aspect ratio 16:10
* Image Contrast Ratio 1000:1
* Diagonal Size 20 in - Widescreen
* Dot Pitch / Pixel Pitch 0.282 mm
* Max Resolution 1680 x 1050 / 60 Hz
* Max Sync Rate (V x H) 76 Hz x 82 KHz
* On-Screen Controls Switch video input , Brightness , Contrast , Image control , Color adjustment , Quick view , Language , Management , Information , Factory reset , Exit
* Controls / Adjustments Tilt
* Tilt Angle 30
* Signal Input VGA
* Digital Video Standard Digital Visual Interface (DVI)
* Type Microphone|Speakers
* Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
* Connections - DVI-Digitaligital , - VGA
* Microsoft Certifications Compatible with Windows 7
* Form Factor Internal
* Voltage Required AC 120/230 V
* Power Consumption Operational 65 Watt
* Power Consumption Stand by / Sleep 2 Watt
* Min operating temperature 41 °F
* Max operating temperature 95 °F
* Operating humidity range 20 - 80%
* Service & Support Limited warranty
* EPA Energy Star Compliant Yes
* EPEAT Compliant EPEAT Silver
Feb 15, 2010 | HP W2007 Desktop Monitor
My chevy lumina has only 39000 original miles. recently the temperature guage started fluctuating from one extreme to the other while driving. the driver's side fan comes on once in awhile and the...
You don't say where you are.
You probably need a new thermostat. Cost for the part should be about $10. Labor to change it out should be $50 to $70, it takes less than an hour. Spring for fresh coolant, too.
The fans: the driver's side fan is activated by the A/C. I know, I know it's winter. But if you're running your defroster, you're running your a/c too. When the a/c is on, the fan can be on, too.
Jan 13, 2010 | 1995 Chevrolet Lumina
Recently had a thermostat replace on my 2003 chevrolet impala
sounds like the fan motor is not coming on.open hood start engine and let it run until it has had time to fully warm up and see if the fan comes on if not then check fan relay and fan motor
Nov 10, 2009 | 2003 Chevrolet Impala
Hampton Bay 30 In. High Velocity Pedestal Fan in Chrome Finish Logo
50 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
