Question about Garden
Chain break will not disengage on Poland Pro PP4218, model PP4218. 966063101
  • 2,239 Answers
If you have pulled the hand guard back toward the rear of the saw with a good amount of force and it still will not lock back, i would suggest replacing the complete brake it is only held on with a few screws, it comes as an assembly part no. 530071893, it is better to be safe than sorry.
Posted on May 18, 2013
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: how to disengage or fix chain break on husqvarna
It sounds as though you have tried resetting the brake to no avail. If I were you any Monday through Friday at 1300 - 1500 I would be in my local Husky dealer (not Lowes). Someone familiar with the saw that can see and touch it. I suspect you will need parts once the problem is isolated, order them there and the diagnosis will probably be gratis. Factor in the shipping and handling fee and most dealer prices are competitive.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
dontbother10
  • 2220 Answers
SOURCE: poland pro 295 will not oil chain
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
Poulan pp295 Gas Saw Type 1 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/PP295-Gas-Saw-Type-1/75.PP295-Gas-Saw-Type-1.1.59.1.html
It has an outboard clutch, use this as guide if removal is necessary:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If not a Type 1 your saw can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Reply below with any questions. Good luck
Lou
Posted on Feb 01, 2010
My Poulan Pro PP5020AV chainsaw brake is engaged & will not disengage. The chain continues to rotate. Any suggestions on how to fix?
If the chain continues to rotate than the chain brake IS Disengaged. When the chain brake is Engaged, the chain is locked. Any problems with the inbuilt safety features needs fixing by a Poulan engineer.
Sep 29, 2016 | Poulan Garden
Model pp4218 throttle stuck open
I assume you are referring to a pullen pro chain saw. If so, the cable that links from the trigger to the carburetor is stuck. This can happen due to trash and dirt stuck in the trigger area, or the carburetor needs cleaning. Or the cable or wire to the carburetor is bent. See if the connection between the trigger and carb moves freely when not running.
May 02, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Aug 05, 2011 | Poulan 952051338 18Inch Chain Saw Chain 38
Purchased like new PP4218 from local, bought for his son, after one tree, son lost interest. No manual with saw. What chain and bar do I buy as replacements? He replaced chain, not sure it is correct...
it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
Jan 23, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The chain cover will not go back on because the break is engaged and I would like to know how to disengage the break band.
If the blade brake is engaged, it can be extremely hard to disengage when not mounted on the saw, as I'm sure you already know. One thing you can try is loosely mounting the cover on the bar studs with no sprocket installed so that you will have the leverage you need to disengage the brake band. Good luck.
Oct 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain will not move on chainsaw
Is the chain brake set? Make sure that the chain is not adjusted too tightly. It should be set so that the chain doesn't droop from the bottom, but allows the chain to be moved freely by hand. The chain teeth should cut toward you on the bottom. Check the chain oiling by running the saw tip near to paper or cardboard--it should leave a thin line of oil after a few moments of running. Hope this helps!
Mar 27, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Timing
The flywheel (under starter cover) should be locked in place by a Woodruff key. They do break or become dislodged. Why do you think the timing is off? You can reply below. If you have more questions I need you to verify it is a PP4218, and give me the serial number please.
I hope this helpful.
Lou
Jan 26, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need an Idle Speed Adjustment Screw for a Poulan ProPP4218 Chain Saw.
Ordertree.com (Poulan authorized parts outlet)
http://www.ordertree.com/cms/contact-us/9790.html
Telephone - For Handheld or Wheeled Products contact us at 1-877-500-7499
I looked at "Gas Chain Saw PP4218 Types 1 & 2" IPLs. there are no carburetor illustrations. I suggest you contact them by phone. Please have your saw and a supply of common hand tools within easy reach before calling. HTH
Lou
There are often multiple carburetor manufacturer's used on the same model. They can easily help you determine what is on your saw.
Dec 14, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I don't know correct gas/oil mix for the Poulan PP4218 chainsaw?
The PP4218 Poulan Chainsaw operates on a 40:1 gas.oil ratio.
Please rate this solution on FixYa!
Thanks!
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
