Question about Sony VAIO PCV-E518DS PC Desktop
My sony has systm error 32
Hi, In the middle of booting up my Sony said system32=error in the left hand corner. I tried reloading Xp from a disk but got no results. I also checked if the capacitors had bulged or were leaking a residue or liquid and they weren't. I despartly need this computer but I just don't know what to do! Can anyone please help me?
Try this it will fix your problem, and it will really help to speed up your PC.
Posted on Apr 07, 2008
    Brigadier General:
  • 6,966 Answers
Hi, Can you pls give some more info: System 32 error after POST before Windows or System 32 error, after windows partially booted? Offhand, if the error is after POST before Windows boot, it is a hardware problem based on motherboard built-in diagnostic program: you may have to check/repalce reseat/connect memory, video card, hard drive; If it is after Windows partially boots, then chances are it is a driver problem; try running in safe mode and check at which points it stops or hangs. Hope this give you some idea. Pls post/comment back if you need further information. Good luck and kind regards.
Posted on Aug 12, 2007
SOURCE:
There is the word "video
hi,
Press the Display button on the remote to switch off onscreen displays.
ok
Jun 21, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
My sony vaio laptop went a black screen with a white hyphen in the upper left hand corner. It will not cut on and will not reboot
The most-likely cause is a malfunctioning (or even "dead") disk-drive.
Without the disk-drive, Windows cannot be loaded into your RAM.
So, what you get is that "lonely" underscore character.
Find a Microsoft Windows XP "installation" CD-ROM.
Insert it into your CD-drive.
Hold down the ON/OFF button until your computer turns off.
Press the ON/OFF button, to start-up your computer,
and tell your computer to boot from the CD-ROM device.
If it does boot, then the rest of your computer (excluding the disk-drive) is working fine.
Replace the disk-drive, and reinstall Windows, to "revive" your computer.
Nov 06, 2010 | Computers & Internet
Sony DCR-TRV17 - In the middle of filming, a flashing yellow square with a yellow light bulb inside the square appears wiht chimes. upper right hand corner is flashing C:21:00. I turned off recorder and...
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
May 31, 2010 | Sony Handycam DCR-TRV17 Mini DV Digital...
Hi, I am unable to use recovery wizard. I tried to re-install xp using win nt 32 manually,but could not do it, Now I can't shut down and I do not have back up cd. Could you please advice me how to...
If you have not removed all the partitions then you can boot with any OS disk and clear the c partition.After that take out the disk and press the recovery option.It should autometicaly partition the disk and reload the OS.
If you made any changes in the partition table then recovery could be done with the OS disk only.
Thanks.
Nov 25, 2009 | Sony VAIO PCG-K23 Notebook
Presario 1700T wont boot- missing "system32\drivers\pci.sys".
you may want to try booting up from xp or recovery disk and select "R" to repair.
Jul 07, 2008 | HP Compaq Presario 1700T Notebook
System Error 32 on my Desktop Computer
If you have tried everything, including reloading Windows, look inside the case and check the capacitors on the motherboard. The motherboard is the main circuitboard, and the capacitors look like little batteries. There are usually 10-20 capacitors on a typical PC motherboard. A healthy capacitor has a very flat top, but a "popped" capacitor is bulged top and bottom. Sometimes there is even a bit of residue leaking from the bottom of the capacitor. If you have popped capacitors and you are not handy with a soldering iron, it may be best just to replace the PC (seriously). If you can handle a soldering iron, you may have luck replacing the popped capacitors. They only cost about $1 each, and they are easy to pick up from a place like www.digi-key.com.
Aug 11, 2007 | Compaq Presario 5005 (470014-507) PC...
Open Questions:
See all Sony VAIO PCV-E518DS PC Desktop Questions
Sony VAIO PCV-E518DS PC Desktop Logo
69 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
