Question about Imation Apollo Expert D200 2 Tb Usb 20 Includes Arcsoft Totalmedia Backup Software Hard Drive
Drive not loading and beeping - Imation Apollo Expert D200 2 Tb Usb 20 Includes Arcsoft Totalmedia Backup Software Hard Drive
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
CD-RW drive won't open, only beeps when trying to open.
Look for a hole on the front tray a little bigger then a pinhole. Straighten out a paper clip and insert it into the hole to eject the CD.
Mar 20, 2013 | Dell Inspiron 8100 Notebook
Winwos doesn load freezes
how many beeps... what kind of pc? below is the standard beeps codes with the the issue.
Standard Original IBM POST Error Codes 1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Jun 18, 2010 | Western Digital My Book Home Edition 500...
My acer wont load when i first turn on, or load,gives 2 loud beep
Sounds like the hard drive is going bad. Take out the hard drive and see if the laptop behaves like that if it doesn't then you know the hard drive is bad. If it still does then it could be a motherboard problem.. With it making those beeping noises when you first turn it on, they keyboard could be going bad because that would make a laptop start beeping like that as well.
May 19, 2010 | Acer Aspire 5100 Notebook
My friends computer just stopped working while she was using it. The screen froze and than she shut it down. When she tried to turn it back on all that happened was that the caps lock, the scroll, and the...
There are a number of things that can cause this to happen. Try taking the battery out of the notebook, disconnect the AC adaptor (if in use) press the power button a few times. Re-install the battery, reconnect the AC (if needed), press and hold the power button for about 2 seconds. This is a hard reboot and should correct you issue. When the notebook powers up, make sure you remove any cd's in the cd-rom drive.
Good Luck,
C2Solutions
Jan 05, 2010 | HP Compaq Presario V2000 Notebook
Unable to load games on ps3 comes up error disc, games worked well previously
if you switch your ps3 onto standby and leave it a min
then you need to hold the on button in till it beeps 3 times then release it will go bk onto standby
then you need to hold it again till it beeps 3 times but last beep will be a double fast beep
a menu should appear on screen
chose the one that says files
this will restore the lens drive and it will load discs
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
I dropped my external hard drive, not even a foot, now when i plug it, it just keeps on loading or beeping every 5 seconds.
The power connection to the drive is damaged. The drive is not getting enough power to spin the drive properly so it is beeping. Check the power cord and/or the USB cable for damage as well.
Aug 14, 2009 | Iomega Computers & Internet
HD not recognized and makes 3 times beep...beep noise when conect
Sounds like the drive has gone south.
This is a bit of work, but if you have access to a Linux disc, load the Live CD and see if you can mount the drive from there.
This is not quick a quick solution but may be far cheaper than sending off to a recovery expert.
If you are not familiar with Linux, go to www.ubuntu.com and download the latest distro, V9.04. Download, burn a copy and boot from it. Be prepared to spend time doing this, but it may just save your valuable data.
I have many times been able to salvage data just by doing this, if Ubuntu sees the drive, you could copy the data to your C drive and reboot.
Best of luck!
tom
Apr 04, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
Pentium 4 computer-ABIT motherboard-continious beeps
go to bios and than disable a drive than u don't hear a beep about ur a: drive bye bye
Sep 26, 2007 | Computers & Internet
Imation Apollo Expert D200 2 Tb Usb 20 Includes Arcsoft Totalmedia Backup Software Hard Drive Logo
22 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
