Question about Sewing Machines
Singer 611g how to fix the thread tension
  • 323 Answers
SOURCE: Singer Starlet 353 Thread tension
you need to do a tension assembly check.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air. The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Posted on Nov 07, 2008
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
Mimito7
  • 128 Answers
SOURCE: loose stitches on bottom
FYI.. Loops on the bottom, problem is on the top..
Loops on the top, broblem is with the bobbin.
Posted on Apr 19, 2009
Mimito7
  • 128 Answers
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
  • 7 Answers
SOURCE: How do i set thread tension on a 306W Singer
Top tension about 4 or 5, make sure the presser foot is up when you theread the machine, make sure you can just pull the bobbin thread through with some slight resistence, if it is too tight slacken the screw on the bobbin case a quarter of a turn at a time anti clockwise.
Posted on May 06, 2009
How do I fix bobbin tension on Singer Quantum L500. Thread is like a birds nest underneath fabric
Completely remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension at the midway point and retest your machine.
Tweak the top tension until the top & bobbin threads meet in the middle of the fabric.
May 26, 2018 | Singer Sewing Machines
I have a Singer 2263 which is old but not used often. I am making aprons for Christmas, I made 3 and all the sudden the bobbin started bunching together. What can I do?
hi Sue.
Why does my bobbin thread keep bunching up? Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turned.
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little pop up will come up just close this down.
or try this one.
How to Fix that Tangled Nest of Bobbin Thread Under Your Sewing
or read up more at this link.
Why does my bobbin thread keep bunching up Google Search
Dec 13, 2017 | Singer Sewing Machines
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
How to fix tension on a singer sewing machine 5050
Please expand your explanation of what exactly the machine is or is not doing. We can't begin to help without more information.
HINT: remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning.
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
http://ohyoucraftygal.blogspot.com/2013/10/sewing-lesson-10-how-to-fix-tension-on.html
http://www.threadsmagazine.com/item/44844/how-to-achieve-ideal-sewing-machine-thread-tension/page/all
Jun 24, 2017 | Singer Sewing Machines
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
Fix tension on Singer 4552SW
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight--if tension is too tight back
off one number or letter at a time, if thread is too loose increase
one number or letter at a time till you get the correct stitch
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8.also check to make sure the top thread has not come off the thread
take up lever
if you don't have a manual, & want one, singer has a free pdf
manual to download
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 4552) do not put in
the sw
Click search
Jun 05, 2012 | Singer Sewing Machines
Featherweight 132Q Singer sewing machine. The top thread is loose. How do I fix that?
try adjusting the top thread tension to a lower number,,like if the machine tension is on 2 then take the tension up to 3 & if that doesn't give the correct tension go to 4 & see if that tension is good for the correct stitch
Aug 31, 2011 | Singer Featherweight 132Q Mechanical...
Singer 15 thread breaks and doesn't sew
if the upper needle thread is breaking adjust the thread tensioner if the bobbin thread is breaking adjust the bobbin tension screw on the bobbin case
Feb 16, 2009 | Singer 3343 Mechanical Sewing Machine
Sewing Machines Logo
51 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
