When I connect this TV to a coax cable line (not through a converter box) it only gets a signal through the first 16 channels or so, but it should be getting many more. An older Zenith on the same line gets everything.
Comment by RoenJacobyn, posted on Aug 12, 2007
Perfect! I just couldn't figure out where those settings were. All fixed!
My TV has been in storage for two years. We hooked it up tonight, put new batteries in the remote, and can't get the remote to talk to the TV. Manually, only get first 16 stations.
Hi, Possibly you have to run steup again in the Samsumng TV using your remote, Look for Channel setup, memory, add or search. It would also help you if you would confirm whether it is on cable, air or std. Hope this give you some idea(s). Pls post/comment back should you need further information. Good luck and kind regards.
Rating Locked! (?) RoenJacobyn has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Partial Cable:
