Question about Unknown Freightliner Century Class 120 Hood: 02 To 04 W/ Inboard Hinge
Bad 146s 010 12 - Unknown Freightliner Century Class 120 Hood: 02 To 04 W/ Inboard Hinge
    Problem Solver:
  • 21 Answers
"bad 146s010 12"...has to do with the blower fan (heat and a/c) is what info. I have found.
Posted on Jan 13, 2015
My husqvarna lc 146s lawnmower will not disengage the self propelled drive
IF ITS A CABLE OPERATED SYSTEM AN IDEA TO CHECK THAT THE CABLE ENDS ARE NOT FREELY MOVING IN THERE HOUSING THE METAL BITS COME OFF THE CABLE EXPOSING THE INNER CORD WIRE IF THEY ARE THE CABLE IS NO GOOD AND WILL NEED REPLACING THE METAL BIT THAT GRIPS THE CABLE IS NOT LOSE ALLOWING THE OUTER HOUSING RUBBER TO SLIP AND SLIDE IF SO A JUST UNTILL IN CORECT OPOSIITION AND TIGHTEN DOWN THE HOLDING SCREW CHECK ALSO THAT THE CABLE HAS TOO MUCH SLACK TO OPERATE THE DECLUTCHING SYSTEM AND OR THE CABLE HAS NOT COME OFF THE MECHANISUM COMPLEATLY OR BROKEN ENTIERLY IF ELETERIC ACTICATED CLUTCH DECLUTCH PTO SYSTEM YOUL NEED A LAWM MOWER ELETRICTION TO DIAGNOSE THE FAULT AND GIVE REQUIRED REMEDY TO FIX PROBLEM
Jun 20, 2016 | Husqvarna Garden
Won't start.Cranks but no spark to spark plugs.
There are several possibilities for it not having spark. I don't the year so I can give you a generic list that will help with almost all vehicles.
  • Bad battery
  • bad battery cables
  • clogged fuel filter
  • bad fuel pump
  • bad distributor cap and rotor
  • faulty spark plugs
  • bad wireset
  • bad coil ignition
  • bad starter
  • Bad ECC
Dec 27, 2015 | Cars & Trucks
What are some likely scenarios for a 2005 Mongoose 250 not starting
Bad pulsar unit
Bad CDI unit
Bad gearbox electrical unit
Bad coil
Bad HT lead or caps
Bad spark plug
Bad earth wires
Bad ignition key switch
Contaminated fuel
Dirty carburetor
May 25, 2015 | Kymco 2005 Mongoose 250
Tachometer not working on my 95 Toyota pickup 4x4 jumping up and down
bad tach, seems .
bad tach, or bad wires to it or power to it bad.
i dont know what engine option you have
but most use the ignitor signal to do this.
later about 1996 the ECU uses CKP sensor to run the tach directly
in that case bad tach, bad wires to tach or bad power feed to it.
it only has 3 wires.
power
ground
sig
one is bad, or its bad.
Dec 14, 2014 | Toyota Cars & Trucks
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
When booting the screen says no signal and the it begins beeping intermedately
I think the graphics card has become unseated as the PC does not need a monitor to start up so there would be no beeps; Here is a list of beep codes with there meanings.
Apr 19, 2010 | Gateway Profile 5.5 PC Desktop
Replaced spark plugs and wires truck is missing
i would suggest calling the police at this point .
Sep 07, 2009 | 2001 Hyundai Santa Fe
I have a problem with my washing machine..
Basic Washer Problems
No fill:
Bad water valve
kinked hoses
unpaid water bill faulty electronics. Overfill:
trash in water level switch tube
bad water valve
bad water level switch faulty electronics. Washes but don't spin:
bad lid switch
bad drive coupling or belt
bad motor faulty electronics Spins pumps but don't wash:
bad timer
bad motor
bad luck faulty electronics. Leaks:
bad hoses
bad pump
bad tub gasket faulty electronics. Fills washes but never advances:
bad lid switch
locked up pump
bad motor
bad timer faulty electronics. Goes through complete cycle but clothes soaking wet:
bad belt
bad pump
bad thrust bearing faulty electronics*. *electronics in appliances ****. My opinion.
Dec 28, 2008 | Washing Machines
My firelight is corruptable
yess u can :
Try first : SRART - RUN - CMD - THEN WRITE CHKDSK E:
ENTER and wait..Try if it will open if not just email me and i will take care off it ar_pllana@hotmail.com
Nov 06, 2007 | SmartDisk FireLite 40 GB Hard Drive
Unknown Freightliner Century Class 120 Hood: 02 To 04 W/ Inboard Hinge Logo
564 people viewed this question
Top Unknown Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Unknown Boating Expert? Answer questions, earn points and help others
