Question about Brother HL 2140 Laser Printer
Paper jam in Brother HL-2140 printer
I have a paper jam in my printer (model HL-2140) and I cannot see any way of freeing the jammed paper. Very frustrating!
  • Anonymous Mar 31, 2014
    fake rear jam
    how to solve hl-2140 brother printer of tonner,drum,error led blinking
    plz solve this problem
There is three spots the paper is jammed
tray
inside (toner removed)
back
if it is hard to take it from the tray use the inside instead
hope this helps
Posted on Dec 29, 2009
Brother HL - 2150N Paper is jammed inside printer; how do I remove it ? URGENT - business printer... thank you!!
Open the front cover, remove the toner/drum cartridge.
Open the rear cover, look for a jam lever you can press down then remove the paper from the back.
If you try to pull the paper out through the front you can damage the gear system.
Use both hands to try and limit the possibility of tearing the paper.
Jun 14, 2011 | Brother HL 2140 Laser Printer
How could i fix paper jam on Brother HL-2140 Laser Printer?
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Jan 12, 2011 | Brother HL 2140 Laser Printer
Cannot get at paper jammed in printer. How do I do this
You this manual to clear your paper jam.
Directly go to page No. 91 it explains how to open the door and paper tray to clear the paper jam.
http://static.globalcomputer.com/pdf/Brother-HL-2140-Mono-Laser-Printer-Manual.pdf
Regards
Rudra.
Oct 11, 2010 | Brother HL-2150N Laser Printer
How to remove paper jam in brother hl-2140
Open the front door, remove the cartridge/drum...slowly slight the paper out. if it jams at the back ...do the same but rotate the fuser gear..if it jams on the tray not pull as it would cause the paper to break and sensors might get dmaged,
Sep 22, 2010 | Brother HL 2140 Laser Printer
Paper jam in brother laser printer Hl 2140 can help plse?
Here is the solution------
1. Open the Front cover of the printer. 2.Remove the cartridge and look inside the printer for jammed paper. 3.If any jammed paper found remove it. 4.Insert the cartridge again. 5.Closed the front cover.
It will help to solve your printer problem..
Jun 03, 2010 | Brother HL-2040 Laser Printer
Have a BROTHER HL2140. Paper jam: Can't remove drum unit & toner cartridge: Help
Solved by opening the front and removed paper: not required to remove cartridge. Info on Problems with Printers. Thank You
Nov 08, 2009 | Brother HL 2140 Laser Printer
Error paper jam light still flashing after jammed paper has been removed and all covers are closed
Unpluging the printer for ten to fifteen minutes after removing the paper jam. This will clear all the memory in the printer and the error codes. If the error code still pops up contact the manufactor.
Aug 12, 2009 | Brother HL 2140 Laser Printer
Paper Jam
Do you see where the paper is stuck. Try to pull the paper out. Look for release door on the back of the printer. Or you can refer to the user manual on this link for easy assistance.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Jan 25, 2009 | Brother HL 2140 Laser Printer
Can we use tracing pager for print in brother HL-2140 printer model
consult your manual for maximum and minimum thickness of paper ... i suspect tracing paper will jam the printer
Jan 06, 2009 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
9,301 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
