Question about JVC AV-32D305 32" TV
Jvc 32" has grouping of thin white lines at top of picture extending 4" down from top of frame
This problem started 6 months ago and comes on when the t.v. is turned on and does not go away. It is a standard tube television and is about 5 years old. Other than that the picture color, clarity is very good. Any idea what it is and if it's worth fixing?
    Novelist:
    Champion:
  • 236 Answers
It sounds like you have a bad capacitor in the vertical circuit. The circuit needs to be checked out by a technician. Stargazer
Posted on Aug 20, 2007
6ya staff
SOURCE:
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at [email protected]
Jul 09, 2009 | RCA 32F531T 32" TV
Insignia 32" TV Thin line across screen 1-2" from top
The original white line problem was caused by improper adjustment of the vertical size for which there is an internal adjustment. The current problem could come from two different sources, one an adjustment again, the other from a capacitor that is losing capacitance and gaining losses; = sick.
If you are fortunate enough to have a surviving TV repair in your area, none of these problems is expensive to find or correct.
Don't be surprised to find the only TV shop operating out of a messy garage since those of us doing this kind of service are dying off and the price one can charge for labor has shrunken to the point that a real business address is too expensive to have.
Jan 03, 2009 | Televison & Video
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Jvc lcd tv
Without seeing the lines in question, it is difficult to say 100%. But, if the panel was cracked, the only remedy is to replace the panel. Given its age (3 months), unless there is specific evidence of impact, I would suggest that the crack may have come from the frame moving with time. Don't waste your time with the local shop. Call JVC directly and indicate that you had no impact on the TV and that the "shop" is trying to not repair it. Verify that the TV has the same problem as when you brought it to the shop.
Dan
Sep 25, 2008 | JVC LT-32X887 32 in. HDTV LCD Television
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Geno
Mar 10, 2008 | Philips 32PT6441/37 32" TV
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
JVC AV-65WP74 problem
I am not sure of the part number, but I had this problem with mine a few years ago, it involves replacement of a 4 inch square board (mine has the number LCA90059 on it with the words CRT SKT PB ***'Y on it) 2 wires coming from it (one 6 wire group with white plug ins on each end, and one 4 wire group with white plug ins on each end) and a large white plastic turbine looking thing (non moving) in the center with a yellow plug on one side of the top, along with a silver 2 in long by 1 in high heat sink on it with the letter B on the opposite side of it. Hope that helps! I noticed its been posted a while, but maybe this info will help someone else.
I am having Red Convergence problems with mine which is what prompted me here ,,, it will not work in auto convergence, and when I manually do it, the red will not move left or right, only up and down.
Anyway, good luck!
D
Nov 12, 2007 | JVC AV-65WP74 Rear Projection Television
JVC AV-32D305 32" TV Logo
94 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
