Question about Dishwashers
Dishwasher will not start Fridgidaire gld4355rfs3
There is power to the dishwasher but it will not start. I can select a type of wash and the numbers show on the LED panel. When I close the dishwasher, the lit numbers stay on for several seconds and then they shut off. it appears that several buttons work but several do not work.
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
VtToolMan
  • 704 Answers
SOURCE: Can't start the dishwasher, lock button is lit up.
Hello Albert, On the Jenn-Air dishwasher you have, you have to hold down the "Heated Dry" button for 3-5 seconds to unlock the control panel.
This should unlock the controls so you can again use the dishwasher normally.
Since you''re likely going to have this dishwasher for some time, I've included a link where you can download a free owner's manual for it.
I would print out a copy for your future use and reference. I also have a file on my computer that I title "Home Appliances and Equipment" which is where I download and save an electronic copy so I always have a backup copy saved, since manuals aren't always readily available on the web, as the appliances get older.
http://www.jennair.com/assets/product/6_920374_A.PDF
The info on locking and unlocking the dishwasher can be found on page 13 of the manual.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
Testimonial: "Thanks for the detailed info about my question, VtToolMan, I greatly appreciate it. However, I tried to unlock it that way, but it didn't work. "
mnwarfield10
  • 452 Answers
SOURCE: my Candy DFI 45 DISHWASHER WILL NOT RESTART AFTER
it sounds like you req a new pcb assy ..it could of blew it with a power surge :( 01179512835
Posted on Dec 30, 2009
Testimonial: "thank you, were can i get one"
tbreeze47
  • 3083 Answers
SOURCE: brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Posted on Mar 14, 2010
What does fridgidaire dishwasher error code pf mean
Usually the PF code means a power failure. You should check the wiring to the machine for loose wire nuts or wires with missing insulation touching each other or the side of the wiring housing. (You'll need to remove the access panel at the bottom of the dishwasher to check the wiring.)
If the wiring is fine, check the switches in the door latch. The white wires should test fine for continuity. If those switches are fine, then the control board has a wiring fault. Replace the appropriate parts. If your dishwasher is under warranty, contact Frigidaire.
If you add a comment with the model of your dishwasher, I may be able to help you find the replacement parts.
I hope this helps.
Sep 21, 2014 | Dishwashers
Fridgidaire dishwasher reset
Good Afternoon Karl, thank you for your post!
Typically, your dishwasher can be reset by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your dishwasher on. Confirm that the door is securely latched and then select a cycle. Dishwasher should resume normal operations. I hope this information helps to some degree.
Hope this helps!
Jan 26, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Where is vent fan on fridgidaire gallery disherwasher
Hello - I am happy to assist you. First, I will need your model (and serial number if you have it) to better address the issue at hand. Thank you.
Jan 23, 2013 | Frigidaire Gallery FGBD2451K Full Console...
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
I have a Fridgidaire Ultra Quiet I dishwasher. The dishwasher has water running inside but it does not spray thru the spray bars.
Remove the 2 screws that hold the bottom kickplate on to ensure that the wash motor has not come unplugged. It happens more than you'd think. If it is plugged in, if you have a multimeter, just check if you have 110v to the wash motor...if you do, then the motor has failed and should be replaced
Mar 30, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Won't start, can't change wash selections
hi there,
can you tell me if you can hear the motor running? if not
did you trip the house breaker? if not
can you open the door? if not
it's the door latch; if yes
is there water on the bottom of the dishwasher? if yes
you are not draining and the dishwasher lost power; if not
the timer is not advancing to the next cycle
let me know.
Sep 28, 2008 | Frigidaire 24 in. FDB679GF Built-in...
Dishwashers Logo
Top Dishwashers Experts
