Question about Watches
Rolex 18233 Watch/lost small screw to hold it in.
  • 2039 Answers
SOURCE: Lost screw
go to any jewelery store cheers
Posted on Jan 19, 2008
robotek
  • 1512 Answers
SOURCE: rolex watch
Hi tia
If it is a geniune Rolex... dont even think about it!! Take it to a jewellers for repair. Even if it is not, and you wish the watch to remain water resistant, then the casings and seals should be cleaned and serviced, even sometimes replaced when put back together. It is worth it to maintain the integrity of the watch... and make it last:) Jewellers dont charge much for this service
regards
robotek
Posted on May 06, 2008
indays
  • 111 Answers
SOURCE: rolex watch
if your watc is automatic or self winding,you need to use your watch at least 12hours a day,to set the time , wind the crown counter clock wise,until the crown lose then full the crown to set the time,after setting the time fush the crown then wind it clockwise to lock again! thank you !
Posted on Aug 27, 2008
SOURCE: Rolex Explorer II
klljklj
Posted on Sep 15, 2008
escapement
  • 2334 Answers
SOURCE: winding and setting the time on a rolex watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Apr 04, 2009
Need to reset the time on my winner 24 it was given to me as a present and they lost the instrutions
If it is a genuine rolex:
  1. You twist the crown counter clockwise to unscrew it.
  2. Gently pull the crown. You should hear it click into the last position. Turn the crown to change the time.
  3. When you are finished, gently push the crown back in towards the watch case.
  4. Screw the crown back down by turning it clockwise.
Nov 04, 2013 | Rolex Daytona 116520 Wrist Watch
How to set Time in Rolex 116520...thnks a lot
The Daytona's Construction
  • Most stainless steel watches are made of surgical 316L steel, which is very good. Rolex goes a step beyond this, using 904L steel, it is both super corrosion resistant and highly polishable, which is why a Rolex shines like no other. Its bracelet is very easy to size adjust, using screws instead of pins. It is actually made of 100 moving parts that conform to the wrist with smooth edges that never snag or pinch the skin. The bracelet also has the Easylink system which lets you make a further adjustment when your wrist expands due to exercise and high altitudes. Rolex watches were originally intended to be a working man's watch and its construction is shock resistant, antimagnetic and water resistant. It achieves water resistance through its triplock system winding crown.
    You must first turn the watch crown counterclockwise until it releases from its seal. The watch crown will then pull out to let you either wind it or set the time. When complete, you must apply gentle pressure to it and turn it clockwise until it screws back into the case to protect it from dust and water. The Daytona caseback is hermetically sealed and only an authorized Rolex service person will be able to open it.
  • The Daytona's Movement
    The movement of the Daytona has changed over the years, it currently uses a 4130 caliber in-house movement. It is made of 290 parts which is much less than other Swiss chronograph movements. Its smaller size is efficient and precise and lets it fit into to the relatively small 40mm case. Note the size difference between the Daytona and the Tag Heuer Aquaracer. The watch movement also contains a Parachrom hairspring. This device protects the movement from magnetic fields and protects it from shock. On the front dial are the words, "superlative chronometer officially tested." This means the watch has undergone two weeks of testing under extreme conditions to meet Swiss standards. This process is standard for every Rolex with chronometer function. Using the Chronograph
  • The chronograph function can be first and foremost used as a stop watch. To start, press down on the button above the crown. To stop, press the top button again, and to reset press the button below the crown. The chronograph can also be used as a large second hand if you synchronize it to begin with the small second hand at six o'clock of the dial. It can also be used to calculate speed, which is a little more complex. It utilizes the units per hour scale that is engraved in the bezel of the watch. For example, suppose you have taken 50 seconds to travel 1 mile. Looking at the dial you can then determine your speed to be 72 mph. Average speed times can also be determined using further calculations.
  • Any other questions I would contact ROLEX at their website. They even have downloads. Good luck.
    http://www.rolex.com/en#/home/
    Aug 16, 2010 | Rolex Daytona 116520 Wrist Watch
    How do you adjust the band on a rolex watch
    Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
    Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
    I need to open the back of a Rolex Submariner replica watch. Can you give me information on the proper way to open the back? Thank you in advance
    Most people dont have a "rolex" case opener laying around their house! :-) That caseback probably screws on...sometimes they dont! Look for a small notch on the edge of the caseback, if you find it then it will pop off with a small knife! Just be careful not to cut yourself! :-) If its a screw on caseback then you really should take it to a reputable watch repair shop!
    Jan 15, 2010 | Watches
    How to remove a Rolex jubilee bracelet
    if its a real rolex, take it to a store dont play around with perfection. but the way a rolex bracelet is held on is by spring bars. look at the back of the watch and put a small screw driver in the lots and push down on the spring bar. then start to ease the bracelet out, now dow the same on the other side the end should come out
    Oct 06, 2009 | Rolex Datejust SS
    How do i use the watch band link tool i just got with no instruct
    Rolex is using screws instead of pins. Get the small screwdriver and unscrew the bracelet screws.
    Feb 11, 2009 | Rolex Datejust SS
    How to adjust leather rolex watch band
    On the clasp of the watch. There are small holes ware the spring bar sits.
    More current models do not have holes that go all the way through on the buckle but the spring bar still sits in between. With a small screw driver press in tward the middle of the strap ware the spring bar sits at the end of the leather strap. Pop out the strap and the spring bar and then place it into the slot that fits.
    Oct 14, 2008 | Rolex Day-Date President 118238 Wristwatch
    How to remove links if there are no pins
    All Rolex watch bracelets has screws, not pins. Get small screwdriver and unscrew them.
    If there is no screws at all, that means bracelet links had been removed and you have shortest version allready ,or, this is not the real (genuine) Rolex bracelet.
    Find your nearest watchmaker to clarify all this.
    Jun 27, 2008 | Rolex Explorer II 16570 Wrist Watch
    Faux men's rolex date just
    An authentic Rolex will have a screw down back with exactly 144 small teeth. You can only open a Rolex case with a special Rolex tool (Key). We use the Bergeon hand wrench to open Rolex cases. Supplied with 6 Bergeon grooved chucks(18.50, 20.20, 22.50, 26.50, 28.30 and 29.50 mm), these are the same chuck used in the Bergeon 5700RO and will fit in the Bergeon Bit Adpater for 5700-Z Case Opener our number FB-231. Replacement chucks and replacement handle are available in case you have a set that is missing a piece. As is the case with any fine mechanical instrument, special tools are required in order to properly service and adjust a precision instrument such as a fine timepiece. If you are not experienced, it is better to leave this to a Certified Rolex tech. If you do feel you want to proceed, this tool will set you back about $140.00 or so. Just as the internal parts of the Rolex are exact, so is the watch case that protect the valuable watch movement. These tools are used to open the Rolex case without causing expensive damage. You can call Bob Frei at 510-832-0355 ext. 2 from 11 AM to 5 PM Pacific Time Zone, to order one if you wish, or several other sellers of these fine tools can be found by doing a little research on the net. Hope this has helped you.
    Jan 28, 2008 | Rolex Day-Date President 118239 Wristwatch
    Watches Logo
    55 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
