Question about Mitsubishi VS-5043 50" Rear Projection Television
Need help with analog cable not showing!
Help im not sure what ive done! i have a mits projection big screen, and i cant watch analog cable on it. only one of my inputs works for some reason also, which is fine because I just use my hd dvd player via s-video, however i downgraded cable so i could watch analog now i cant. not sure what ive done wrong. pleas help
    Genius:
  • 1,153 Answers
1. CHECK BASE BIAS VOLTAGE OF Q217, FOR 0 VDC (BIASED OFF) IF .7 VDC (BIASED ON) CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB
Posted on Aug 26, 2007
SOURCE:
I have an older model hitachi tv and im trying to set up an antenna but im not picking up any pictures. Thanks for your help.
How old is it? Is it an analog set?. There are no more analog broadcasts. You need a digital to analog converter box to watch the digital broadcasts. Ask your neighbors how they receive broadcasts.
Of course it is possible there are no broadcasts in your area. I live in the mountains of New York and we require satellite or cable to watch anything.
Jan 06, 2015 | Televison & Video
I have a 45 inch Mitsubishi big screen TV and recently i have a problem with yellow and blue stripes showing up on my screen . I have found if i unplug my cable box and then reboot they temporarily go sway...
watch a dvd for a while and see if it happens there too. if it does the tv maybe gone. probly cheaper to buy a new one. tv that size around $799 or so now.
Jul 13, 2009 | Televison & Video
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mits WS-55809 Convergance prob?
You are confusing yourself = TMI ! Stick to convergence repair...
IMHO , hire a tech to do this repair for you.......................T.
Nov 07, 2008 | Mitsubishi WS-55809 55" Rear Projection...
My Mits-Projection TV model WD-52825/WD-62825
Good Day, jmkay;
I see no reason why you can't do this yourself, but unlike the pioneer you have to approach the Mit's from the back and will have to remove the back from the screen (sort of)....charge you battery and Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
JVC Television 56" in Digital Mode
somewhere in the tv's menu there will be something called autotune or channel settings. while in that part of the menu you should find something to change settings. also there are many inputs on the back of big screen tv's, you might try a different input like cable/antenna for instance. it may take a two way splitter to split the signal for both digital cable and analog cable. by next february the analog part of the cable may not work anyway.
May 02, 2008 | JVC AV-56P575 56" Rear Projection...
All inputs work except for the component videos.
When your tv shows a blue screen it not getting a signal!! In your mit's you have to go into the customer menu and turn on the input/device. The device control is on the remote, click over to input and activate (enter). Also, look into owners manual, the customer service at mit's will step you through it if you wish. Note: put cables into comp 1 (eg), make sure colored cables are correctly inserted, and audio. (red, blue, green) red/white; audio.
Apr 02, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Finding a Ballast for Mitsubishi WD-62327
you can contact mitsubishi parts at 1-800-553-7278 to check on the availability of the ballast you need, most aftermarket retailers don't carry the ballast. Hope this helps.
Jan 24, 2008 | Televison & Video
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
