Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Dirt devil easy steamer
How to hook up hand hose attachment for upholstery ?
    New Friend:
Why wont the brushes turn
Posted on May 30, 2015
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Posted on Jan 24, 2008
SOURCE: dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Posted on Mar 28, 2008
SOURCE: dirt devil en vision
download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Posted on Jun 24, 2008
blueextc3221
  • 15935 Answers
SOURCE: I need a new manual for dirt devil easy steamer deluxe
CLICK HERE for the owners manual in PDF format.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 19, 2009
SOURCE: I lost the manual for my Dirt Devil Easy Steamer
You can get it here.
http://www.dirtdevil.com/search.aspx?q=MCE7000&type=3
Right click and download the file.
Then open it with Adobe Reader or FoxIt Reader. I just got one!
Posted on Dec 07, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
CE7100 easy steamer upholstery directions
Hi! The MCE7100 does not do above floor cleaning. It is only used for carpets. Thanks!
Jun 28, 2014 | Dirt Devil Royal/ 1700735B00 Dw Cover...
Dirt devil carpet steamer diverter valve not releasing for furniture attachment
Hi there! If the trigger or valve are sticking this can be an indication that the valve may be clogged with soap residue. Try soaking the trigger end in warm water for a few hours. When you use the hose again, be sure to prime the trigger by pumping it about 30 times then squeezing it for 30 seconds to get the solution to flow. Hope this helps!
Jun 22, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt devil ce6100
Hi there! Below are step-by-step instruction to assembling the hose to the cleaner so that you may use the attachments. I have also included a link to the instruction manual which gives instructions and illustrations as well. Hope this helps!
1. Put cleaner in its upright position. Connect the upholstery attachment to the trigger adaptor.
2. Remove the dirty water tank door.
3. Insert the hose adaptor into the dirty water tank.
4. Connect the base water supply connector into the fitting on the lower left side of handle facing cleaner. You are now ready to do above floor cleaning!
http://pim.ttifc.net/document/1549/
Jun 13, 2014 | Dirt Devil CE6100 Featherlite Upright...
Where do i attach the hose
The hose should be fixed beside the canister that collects the debrie, you may have to open a door/plastic cover to access it.
Nov 23, 2011 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt devil easy steamer does not steam
have you put water in it, and that it does not leak out does it get hot
Oct 04, 2011 | Dirt Devil Easy Steamer Upright Wet/Dry...
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
290 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
