Question about Canon ZR200 Mini DV Digital Camcorder
Problems with VHS AV DV conversion
Hi, I am trying to convert some old VHS tapes to a digital format and burn them onto DVDs. I have the av cable hooked up from the vcr to the Canon ZR200 camcorder and a firewire connecting the camcorder to my mac. I was attempting to import using imovie, but once I started the tape the image quality was atrocious, the entire image is bleached out (light is so bright that you can barely see anything) and after a few seconds it flickers and dies out to a blue screen. The problem is definitely with the camera as I disconnected it from the computer and was just looking into the camera to make sure it was happening there and it had nothing to do with imovie. These are childhood videos taken during the mid-late 80s. I've watched them on televion recently with absolutely no problems. The confounding part of this is (1) that the video always for a few seconds and then craps out and (2) my dad taped part of a basketball game over one of the tapes (probably from around early 90s or so) and just that part works perfectly. Image quality is flawless. So this must mean it has something to do with the fact that the kid parts were taped earlier and the camera is somehow reading these differently, right? Does anyone have any advice? I was trying to get this done before Mother's Day but I guess that's a longshot now... Thanks!
    Top Expert:
  • Canon Master
  • 77,932 Answers
Posted on Mar 01, 2017
2 Suggested Answers
  • 10594 Answers
SOURCE: Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Posted on Dec 25, 2008
Can I record DVDs from a Sharp 13VT-N100? The only connection source is the coaxial antennae port. There are "In" sources so I can watch DVDs from a DVD player but how can I reverse that so I...
Recorded from tv shows to DVD Disc have to hookup AV RCA component cables to both to Tv and DVD recordable player model connections together.Yes,u will able to recordable VHS tapes to DVD Discs.But ur DVD player model u have it is must be a recorderable DVD player model?Not just a DVD Discs and VHS tapes player only model.Check ur owner manual all are in there.
Aug 20, 2011 | Sharp 13VT-N100 Combo
Re v5500 . . . can i copy a movie from the vcr onto a dvd with this model???
You cannot transfer VHS to DVD on this model unit by itself. You can, however, connect the AV outputs of this unit (as a VCR) to the respective AV inputs of a separate DVD recorder - using yellow-white-red RCA cables - as long as the source tapes are not copy protected, and the appropriate disc formats for the DVD recorder are used.
Apr 20, 2011 | Samsung DVD-V5500 DVD Player/VCR
Can I transfer my VHS tapes to DVD using my Aiptek A-HD+? I do not have a DVD burner, can I use an external one? I really have no clue where to begin and what problems I might run into. If this is even...
The Aiptek A-HD+ has an AV in mode that can record from sources like VHS,DVD,TV etc. Connect the output from the VHS player ( You will have to use a composite cable i.e RED,WHITE,Yellow cable) to the AV - in of the camcorder. Press play on the VHS and record on the cam. The recording will only be at 640x480 or VGA resolution. Once your video is recorded transfer the video to the PC as you regularly do by copying and pasting to your internal HDD. Use a software such as Nero Vision Express to convert your videos to DVD format and write a DVD. It will take come time as the video will have to be converted from the format the cam records in to MPEG-2 which is the standard compressor for DVD. You can use an external DVD writer , but the writing will only start after the files have been converted. You will need some converter for converting the videos to DVD standard or else it might not work on the DVD player's. There are many converters available online but Nero is easy and just one step, drag all videos and click write it will convert and write the DVD , easy.
Hope this Helps.
Mar 04, 2011 | JVC Video Cameras
Copying home made video from sony Hi8 tapes to Sony DV mini tapes
Sony DCR-HC21 has a multi-AV in, your Hi-8 should have a mini (4 band) to multi AV out. The cable would look like a stereo headphone cable on one end with thre RDA type plugs on the other end; red, white, yellow. The mulit in on the DV would probabaly be the same type connector. Youd have to use a coupler set for the two multi-av cables to bridge video to video and audio to audio. Come out of the Hi8 into the miniDV recorder. You should not need a Dazzle unless you want to transfer to a PC for editing before moving video back to a miniDV tape.
Jul 26, 2009 | Sony DSR-30 Mini DV VCR
VHS to Canon MV450i transfer or direct to Mac
The MV450i has an AV input. So get a lead to go from the AV out from the VCR to the AV input at the front RHS of the lens (3 pin stereo jack socket behind grey cover - the lead was supplied with the camera). Go to the buttons behind the screen - press the line in button - camera goes to pause. Se the VCR playing - press the play / focus button to start recording to the tape.. Import to imovie as you normally do.
Dec 22, 2008 | Canon MV450i Mini DV Digital Camcorder
How to make dvd ,vcd from mini dv without any firewir port
You need and AV capture card to do that if you dont have a firewire port.
Use the supplied AV cable that came with the camcorder, connect the audio (left/white, right/red and yellow/video) to the capture card AV inputs and start capturing. You can make the setting on the capture card, whether it should be captured in DVD or VCD format
Aug 17, 2008 | Canon Elura 100 Mini DV Digital Camcorder
How to use the MV6401 as an AD converter
There are more direct way of transferring VHS to digital format (MPG, AVI, etc. There are now cheap video capture devices like TV tuner, or a video capture card tha connects to USB 2.0 port. However if you still want to use this camera, this ?s what you need to do. 1. Connect the camera to the PC. Most MiniDV cams have an iterface called i-link, firewire or IEEE-1394. If your computer has no shuch interface, you have to install. 2. Record the analog video to the miniDV tape. 3.CApture the recorded tape to the PC. You need to video capture software to do this. You may need to convert the format to the format that you prefer. 4. Burn the vdeo to DVD, you will need a burner and video autthoring softare such as nero.
May 28, 2007 | Canon MV630i Mini DV Digital Camcorder
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Convert NTSC VHS video tapes to DVD PAL
If you do not have an adaptor to play the tapes to a standard VHS viseo player, you can use the camera as the player by connecting the AV out to a DVD recorder. There are hundreds of models in the market, and do not worry if it is NTSC or PAL because 99% of DVD recorder accepts both.
May 23, 2007 | Panasonic PV-GS150 Mini DV Digital...
Digital camcorder to convert VHS tape to PC for DVD burn
You can't with what you've got I hate to be the bearer of bad news, but in order to play tapes in a vcr and run them through a digital camcorder for output to a computer, the camcorder must have s-video or av inputs. Your camera only has s-video or av outputs, used for sending from the camera to the vcr or tv. Also, some cameras have the inputs but don't support analog to digital pass-through (which is what you are describing). With these cameras you input from the vcr and record it to the tape in the camera, and then output it to the computer. Without the inputs, you can't do either one.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Canon ZR200 Mini DV Digital Camcorder Logo
75 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
