Error code rn t98-540 how to fix it
Error code t98-540
  • Alejandro H. Parba Jr. May 12, 2013
    This risograph duplicator machine brand RN 2030 UI which system error code indicate T98-540 appears whenever I switch on the power.The drum of this machine never functioning it's connection failed.
    This risograph machine RN 2030 UI which SYSTEM ERROR CODE T98-540 iappear whenever I switch on the power.The drum never functioning no connection to the system unit.What should I do to fix it again what parts of this machine needs repair or parts replacement. I hope some one has the knowledge to this system maintenance. Thanks for the consideration you may given me to solve it .
My printer riso rn 2000ep is showing error code t25-026. i need help
http://us.riso.com/wp-content/uploads/assets/manuals/a0LA0000001gAtpMAE.PDF
Sep 02, 2017 | PRINTER Office Equipment & Supplies
Rn 2030 ui error code t-98-540
t98-540 Cannot read/write data to EEPROM in the print drum. hope to be of help.. EEPROM problem is eminent.
Oct 21, 2013 | Riso RZ220 Duplicator
Riso rn 2011 error code TO1 520
If you tried to reset and it failed, call for service technician
Jun 18, 2013 | Office Equipment & Supplies
Riso rn 2030ui error code A01-211
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
Feb 25, 2013 | Riso Office Equipment & Supplies
I need to repair my riso RN 2100 ep
my riso rn2100 ep have b01-730 error ?
pleas help me .....
Aug 10, 2012 | Office Equipment & Supplies
Got this code 0290 from renault garage but keeps coming up error on my 04 plate meggane estate is it the wrong code
You must have been given the wrong code.
To get it checked remove the radio from the dashboard
Then post the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing.
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
Jun 21, 2011 | Car Audio & Video
Error code T01-521 on RISO RN 2130
I have an RP3105 with this error code. Next to the magnetic clamp that holds the master in place is another lever mechanism that lifts the master to present it to the waste master mechanism. This has a small white plastic wheel which is engaged to make it move. On my machine the wheel had broken in half. I superglued the two pieces together and everything works perfectly
Feb 04, 2011 | Office Equipment & Supplies
HOW CAN I SOLVE THE ERORR CODE T04-513 IN MY RN 200 RISO ?
Error T04-513 means: The overflow sensor is ON for a set number of times in succession.
Check the ink in the drum and the sensor which is a thin wire. If there is to much ink remove some. If the sensor is bend then correct it.
Jan 30, 2011 | Riso RZ310 Duplicator
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
69 people viewed this question
jasbo
jasbo
