I turned on my aspire 4535G but no display on the screen, but the power button is fine, how can I fix it?
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: Acer Aspire Timeline AS3810T-8737 - No screen display. How can I fix?
http://www.newegg.com/Product/Product.aspx?Item=N82E16834115653
Let's diagnose, and see if the problem is the graphics chipset, on the motherboard, the video cable, or inside the Display Assembly itself.
[ Display Assembly is LCD Module for Acer.
LCD Module general description;
1) LCD Panel, (LCD screen),
2) LCD Bezel, (Plastic thin frame in front of LCD screen),
3) LCD Cover, (Top cover of laptop when it is closed, and over the LCD screen),
4) Camera, (Web camera)
5) LED backlighting,
6) LCD Panel Screen Frame
7) LCD Panel Brackets, (2)
8) Left Hinge, and Right Hinge
Orienting you with Acer nomenclature, as I will also be posting a Service Manual, in PDF file form, in a link.
LCD Panel Cable is Video Cable ]
A) Laptop OFF, monitor OFF, attach a VGA monitor to the laptop.
Goes to the VGA connector on the left rear side of the laptop.
This is a basic example of a VGA Cable, and VGA connector,
(On the laptop a VGA connector is known as a VGA port )
http://en.wikipedia.org/wiki/VGA_connector
For the external VGA monitor you can use a CRT type, (Looks like a small TV), or a flat LCD screen monitor, if it has a VGA cable.
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the external VGA monitor should have a display on it.
IF not;
There are at least three display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop, AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key. (Fn key is second key over from the left, on the bottom row)
At the SAME TIME tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no? Hold the Fn key down again, and tap once more on the F5 key.
Still no? You have a bad graphics chipset. Usually means motherboard replacement.
{ Unless the graphics chipset is loose, in it's mounting on the motherboard. (Mounting = BGA surface mount)
If so the graphics chipset may be good, and it needs to be reflowed. The solder joints under the chipset need to be re-heated again, so the solder will reflow, and make good solder joints once more }
Good display on external VGA monitor?
Means the video cable is the problem, (LCD Panel Cable), or inside the Display Assembly. (LCD Module)
The video cable connects to the motherboard, under the Keyboard area to the upper left corner, routes up through the left Hinge, and into the Display Assembly, where it connects to the back/bottom of the LCD screen.
Just through normal opening, and closing of the laptop through the years, the video cable's sheath may become pinched, (Left Hinge), and pulled on when the laptop is opened.
Or worn against. Means if the sheath of the cable is pinched, and pulled on, so may the tiny little wires inside the sheath of the video cable. Stretched/Broken.
You have to disassemble the laptop far enough, so that you can remove the video cable, (LCD Panel Cable), and visually inspect it.
ANY signs of damage may mean damage to the tiny wires inside.
Even if no outward visual signs of damage are apparent, it would behoove you to have the video cable checked out.
Have a shop check the wires inside the video cable for continuity.
Make sure there are no breaks in the wires.
It could also just be a loose connection. Connection is loose on the motherboard side, or LCD Panel connection.
It is pretty apparent if the connection is loose on the motherboard side. Just needs to be plugged in tight. When it is plugged in tightly, it looks it.
It is not so apparent on the LCD Panel side. (LCD screen)
Connector is VERY small for one thing. It also doesn't take very much of a loose connection, at the connector. Hard to see. Best method, is to just to physically make sure the video cable is plugged in tightly, to the connector on the LCD screen. (LCD Panel)
Video cable is in good repair, and there were no loose connections?
(You can use the laptop to see, before you put everything back together)
Then the problem is the LCD screen. (LCD Panel)
It uses a series of LED's as a Backlight. They are built into the LCD screen.
There is NO screen Inverter. The LED backlighting does not require a screen Inverter.
Therefore the only method is to just replace the LCD screen.
http://www.screencountry.com/index.php?section=products&model=ASPIRE%203810T-8737%20TIMELINE&brand=Acer&size=
Just an example, no advertising. You may find a better price, from a reputable dealer also.
More information;
Pictorial guide to replacing an LCD Panel, for an Acer Aspire Timeline 3810T Notebook PC,
http://www.insidemylaptop.com/replace-broken-screen-acer-aspire-3810t-laptop/
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Suggest you buy, and use an ESD wrist strap. Average cost is around $3 to $6. Connect it's alligator clip to a good ground source.
One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
[ I connect to an unpainted surface, of the metal frame of an open, empty desktop computer.
You can also set a large metal serving tray on your work table, and connect to it. (Unpainted)
Or a large metal knickknack. (Unpainted ]
Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Advise DO NOT mix them up.
A) In Step 1.
The Screw Covers are made of a synthetic rubber. They have a type of rubber cement on the bottom of them, that holds them to the screw head.
I use a computer pick to remove them. You may have a similar tool, or substitute with your choice.
Just ease up on one bottom edge, and pick up. If you store the screw covers correctly, and remove properly, you can more than likely reuse them again. I just lightly stick them on the LCD Bezel.
(The thin plastic frame in front of the LCD screen)
Then remove all the Philips head screws. The LCD Bezel pops off.
It has locking tabs on the outside edges. The inside edge of the Display Cover has matching locking latches.
Just go to the inside edge of the LCD Bezel, as shown in Step 2, and ease it away from the LCD screen. It flexes. When the top/middle of the bezel is flexed away from the LCD screen, a little, ease a finger under it, and go to one side. Now go to the other side.
Once you start working down one of the sides, the bezel should start to pop off.
[IF you are keeping the LCD screen, and not replacing it, WATCH your fingernails! They will scratch the LCD screen.
Use computer gloves, and/or protect the LCD screen with a thick piece of construction paper. I cut a thick piece of construction paper to fit the inner opening of the LCD Bezel ]
B) You have to remove the Keyboard to remove the Upper Cover. You have to remove the Upper Cover, to access the video cable's motherboard connector.
The Keyboard Cable stays attached to the Keyboard. It removes from the motherboard connector.
The Keyboard Cable is a FFC. Flat Flex Cable. It has NO connector on the end.
The motherboard connector that the Keyboard Cable attaches to, is a ZIF connector. Zero Insertion Force.
It is made of two pieces, but DOES NOT come completely apart, in order to remove the Keyboard Cable.
There is a larger rectangular piece on the bottom. This is the BODY.
There is a smaller rectangular piece that goes across the top. This is the LOCKING BAR.
The Locking Bar moves away from the Body. Slid up towards the LCD screen.
It ONLY moves about 1mm to 2mm. That is a little larger than 1/32nd of an Inch, to 1/16th of an Inch.
IF, the Locking Bar comes off of the Body, it is broken.
If it is broken you are looking at -> motherboard replacement.
This is why I am being so detailed.
Pictorial guide using an Acer Aspire 4810TZG,
http://www.insidemylaptop.com/disassemble-aspire-4810t-4810tz-4810tzg-4410-laptop/
In Step 16 you see the two brown tabs, of the brown Locking Bar.
One on the Left, one on the Right. These little tabs are all you see.
In Step 17 you see the Locking Bar moved up away, from the Body.
Now the FFC (Keyboard Cable) can be gently pulled out.
NOTE the direction it is installed. HAS to go back in the same direction. Twisted Keyboard Cable, or not.
[Flat contact pins in Keyboard Cable, MUST realign with the SAME contacts, in the motherboard's connector, as it was originally installed from the factory ]
Steps 12 through 14 show you more on removing the Keyboard.
The latches you need to depress, where they are, and how it's done.
Also shows rolling the Keyboard over, so that the Keyboard Cable can be disconnected. (Have to disconnect cable before you can remove the Keyboard, 'natch )
Also watch lifting the Keyboard straight up. There are tabs on the side if the Keyboard towards you, and they can be broken off. Lift the Keyboard at an angle, gently move towards the LCD screen, then lift straight up, and roll over on the Upper Cover.
Link to free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
On this page drop down to the 'paragraph' that starts with Aspire 1200. (1200 in blue)
Go down to the 4th line, and left-click on -> 3810T
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (3810T) it may take up to 30 seconds, before the first page comes up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jul 04, 2012
Zg5 has blank screen even though power light is on. Computer was working fine and after turning it off if refuses to display anything but blank screen. Battery was removed for a short while then replaced...
Welcome to FixYa!
It seems that you are having problem with the LCD or the display on the laptop, you just said that its tyrning on but there is no display appearing on the screen. This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this information will help. Thank you for using FixYa!
May 17, 2011 | Acer Aspire One PC Notebook
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
Flickering horizontal lines on the screen and spread purple color
I work for a computer company and i am sorry for what has happened to your computer. Regarding the display that your screen shows I'm afraid but let me get straight forward. The LCD screen is broken from the inside. Probable causes:
  1. Computer must have been accidentally dropped.
  2. Force applied on top of the laptop which caused the back side of it pressed.
  3. Heat that escapes from the motherboard, goes through the keyboard straight to the LCD which causes liquid elements to expand and breaks LCD from the inside. That's why it is always advisable to let the laptop cool before closing the LCD screen.
I'm sorry about what happened.
Apr 12, 2011 | Lifetime Acer Aspire 4535G Replacement...
My window 7 suite is not guinune.
its an easy fix.contact acer customer care about your windows suite and your adapter
Mar 08, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
My acer aspire one only turn on the battery charge led and power button led but the screen is black .. help me please
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens, there is a possibility that the problem is with the LCD or monitor itself that needs to be replaced.
Hope this will help...Your response is very much appreciated...
Feb 07, 2011 | Acer Aspire One PC Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5100
Sounds like the power jack is loose if you have to hold it in a certain position. As for the screen your inverter might be shot. Try connecting an external monitor to your laptop and see if you get a display.
Sep 08, 2009 | Acer Aspire 5100 Notebook
Black screen on acer aspire one series zg5
You should contact Acer. They know they have a display problen with the Acer Aspire One that can be fixed with a BIOS upgrade. We got our done. They sent us a USB thumb drive with the files and instructions on how to boot the thumb drive. After a couple of minutes the Acer restarted and all is fine.
Jun 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 5100 wont start up
i think the computer gone to power save or hibernation mode. get the battery off from laptop then put it back, turn the computer on. it works, if not consult some hardware technician i think it is not a major problem it can be fixed easily. if warrenty is valid, avail it...
Oct 20, 2008 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
