Vizio pdp50x34012 I am getting sound but no picture. Solid Green light on front?
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
jhinsincity
  • 616 Answers
SOURCE: JVC AV-32F476 on timer green no picture no sound
Power supply failure, expect to pay $100-150. worth the investment JVC made some good tvs Julio milleniumtvsvc@gmail.com
Posted on Jul 22, 2009
SOURCE: vizio gv47lfhdtv10a no picture no sound
Well guru way to help him out with his problem maybe he doesnt have the money to just run out and buy a new one...
Posted on Mar 21, 2010
SOURCE: LG 32lc2du suddenly no picture, no sound. green
I had the same problem and it was a capacitor in the power supply
Posted on Nov 24, 2010
LG 32LC56 back light on no picture
hello..
That problem is usually cause of bad t-con board..
just replace it to fix the issue..
Aug 25, 2012 | Vizio L32 32 in. LCD HDTV
No Picture
since how long are you facing the problem
Oct 29, 2008 | Vizio P42HD Television
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
My vizio p50hdm tv has a solid green light indicating it is turned on but I have no picture or volume. What needs to be replaced? Thx
The Lifetime warranty is a fantsy as most of you help, You should check with the company before posting untrue statements. Nothing has a lifetime warranty so dont waste your time with flights of fancy.
May 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio p50hdtv20a with no picture or sound
sounds like tv shop knows that is missing because they removed it so as not to work when custermer got it back with no charge
Jun 06, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
VXL32 tries to turn on but no dice.
sound like some blown capacitors on the vga board
Apr 27, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
