Siemens S12-38 Washing machine error code 43
After pausing machine then restart jumped to show 1 minute left when cycle had 40 mins left before pause, then went to error code 43
SOURCE: Kenmore Oasis washer HE
How about the LD error message, I am Tried of having to bow out the drain hose
Posted on May 31, 2008
SOURCE: Zanussi IZ12 Pumps, then Pause LED is flashing.
hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Posted on Jul 11, 2008
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Posted on Aug 18, 2008
SOURCE: Zanussi Progress 1600. Keeps showing E20 error
does not drain,does notspin drum not turning,belt intact,shown e20 at one stage,is this the motor?
Posted on Mar 13, 2010
SOURCE: My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
Posted on May 09, 2010
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
This worked for me
Jan 20, 2016 | Bosch Washing Machines
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
to fix you must do a master reset of the washing machine.
Aug 18, 2015 | Bosch Washing Machines
I have a bwm 50 washing machine displaying e2
Hope this helps
Bob
Jan 12, 2015 | Washing Machines
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
Frigidaire Affinity ATF6700FS2 pauses with every load
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
What is erro code 6e on a samsung washing machine
Don"t worry too much about the error code, press pause, and then press pause again, the cycle should continue. If the counter does not countdown, ideally,as long as your washing is in the machine for 30-35 mins that should be ample time, then press pause and put your dial on the final cycle from rinse to spin, if this does not work, try picking a longer wash cycle, leave for 30-35 mins, then press pause and fast-track to your final stage of rinse to spin, Good Luck!
Apr 16, 2011 | Washing Machines
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
What does error code E2 mean? I have a Bosch Maxx Classic.
Nov 03, 2009 | Bosch Washing Machines
Washer won't run through a complete cycle-stops at 29 minutes
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
