Question about GE VG4060 VCR
SAFE When I go to turn on my VCR (or press any other button on it for that matter) It just says safe on it and wont take any sort of action other than displaying the time after a few seconds.(There is a tape inside the VCR, don't know if that matters). What can I do?
Hold down the power button (or the vcr button if on a combination remote) for six seconds. This will unlock the child lock feature of the vcr.
Posted on Nov 04, 2007
    Novelist:
    Scholar:
  • 158 Answers
How old is your vcr if it's over 1 yr old please do the following disconnect from mains supply remove all leads connecting to vcr and remove from cabinet or stand get a small bowl for the screws locatethem remove said screws and place in bowl now remove lid from vcr and check and see if there is a video tape jamed if so just carfuly remove from arround guides and drum head once you have removed jammed tape plug vcr back in mains and press eject on vcr remote or on front pannel next get cotten buds and give left head a wipe then the right head a wipe next carefully remove video tape press the right flap button in and carefully remove from loading bay lift flap to loading bay of vcr with left hand ad gently pull video tape out trying not to dammage the tape once clear use finger under tape wind up tape that's exposed if all goes well you may place a video cleaning tape in not wet but dry and it should accept this if video turns off and when you turn back on and same resaults please take in for repair replace screws hope all goes well
Posted on Aug 13, 2007
2 Suggested Answers
6ya staff
SOURCE:
Michael Borelli
  • 979 Answers
SOURCE: SAFE
The cassette will have to be manually extracted. The "safe" mode simply means that the machine has detected a problem with the mechanism, usually related to the shuttle function not taking place....accordianman
Posted on May 12, 2008
The word SAFE comes on the display when the VCR is turned on, and that is all that happens---VCR does not work.What is going on?
safe can mean you have it on child lock,look for c lock on remote.there is some sort if button there,good luck
Jun 13, 2010 | RCA VR555 VCR
Vcr keeps saying safe
Try this: (actually found in user manual...)
Pro-Tect Plus™ (Child Lock) Feature
This feature is useful to tamper proof your timer recordings from unwanted changes
and/or protect the VCR from mis-operation by other users in the household.
To Lock the VCR
Press and hold POWER or VCR on the remote for
approximately six seconds to turn on the Pro-Tect Plusª
feature.
SAFE appears in the VCR front panel to let you know the
feature is activated.
To Unlock the VCR
Press and hold VCR button on the remote for approximately
six seconds to unlock the VCR.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 27, 2009 | RCA VR355 VHS VCR
VTH6400U Thompson VCR on pressing 'on' button shows SAFE
1)First press the button marked 'LOCK' on the remote control (left of center)
if that doesn't work
2)Press the button marked VCR on the left top of remote control.
If it is still locked it means some one has disabled the remote control by pressing the CH+ button and Play button simultaneously. To release this, Carry out the same again ie..press both the CH+ button and the Play button together.
This should cure the problem.
May 19, 2009 | Televison & Video
LG VCR MODEL CC490TW GIVES 'SAFE' MESSAGE
sometimes the volume control and the channel changer buttons is your remote to move thignd right to left and up and down.
rod
Feb 16, 2009 | Televison & Video
Sanyo VHR- H794 When I press the power button, it keeps reading 'SAFE' but wont turn on.
On the remote control press SAFE to unlock child lock, your VCR shall be ready to play/re once more
Jul 12, 2008 | Televison & Video
SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
Stuck in "safe" mode
Hold down power on vcr/dvd unit or the remote for 8 seconds. It turns the SAFE mode on or off.
Oct 29, 2007 | GoVideo DV2150 DVD Player/VCR
LG VHS GC480W - VCR 'safe mode'
What do you do if you lost your remote?
Is there some master reset availible?
Oct 26, 2007 | LG XBR446 DVD Recorder/VCR
Safe
There should be a button on your remote labeled "safe." Press that, and it will turn the safe mode off. It's on the second row from the bottom on my remote.
Jul 15, 2007 | Sanyo DVW-6100 DVD Player/VCR
"SAFE"
Greetings Spock! Although I worked for an authorized rca service depot for 12 years, and worked on many, I can't remember the solution to your problem, and Thompson Consumer Electronics (RCA/GE) don't even accknowledge they ever sold vcr's..I went to RCA.com and your model comes up as "does not exist"...Anyway...I know I've worked on that model, and if you have the book, check the section about parental lock, or Key lock...your RCA could very well be Samsung inside, and if so press and hold the tv/vcr button for 5 seconds and that will release the key lock feature. It is there so if you set the timer, or just don't want the kids messing with it, you can lock all the key functions, and the unit will do nothing except display "safe" Hope this helps...Live long & prosper!
May 03, 2007 | RCA VR557 VHS VCR
GE VG4060 VCR Logo
500 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
