SOURCE: Does Cakewalk Pyro 5 work easily with a USB turntable
Yes, Cakewalk Pyro 5 works well with a USB turntable. It has specific support for USB turntables. One example of a turntable that works well with it is the Stanton T.90 USB Turntable.
SOURCE: pyro plus does not work
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
SOURCE: Cant'r run pyro5 on windows
Yes, but it may be more expensive then buying the new Cakewalk pyro Audio Creator 1.5 ($40). The cost will depend on your version of Windows 7 among other issues.
From the Cakewalk site: "pyro 5 and the other versions listed above will not launch properly under Windows 7. They will not function at all."
The work-around is to run the software such that it thinks you are using an older version of Windows. There are a two ways to do this with one computer: 1) run a dual boot system with Window 7 and an older version of windows, 2) run a virtual computer with an older version of Windows inside the Windows 7 system using Parallels, VMWare or Virtual PC.
In most cases for either option, you need a licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate, you can get the virtual computer with XP for free. Download Microsoft's Virtual PC and then the XP mode package. Install them in order and install your Cakewalk software to the XP computer as if that is the only computer. The only issues can come up is that peripherals (like printers) can't be installed on both the real and the virtual computer and sharing files has to be done by saving to optical or other external media.
I'm not sure how much of a learning curve would be involved but there is a free audio editor available. See http://audacity.sourceforge.net/ for more information - the Win7 version is still in beta but works.
I hope this helps.
(Virtual PC http://www.microsoft.com/downloads/en/details.aspx?FamilyID=04d26402-3199-48a3-afa2-2dc0b40a73b6; some updates are also available.)
SOURCE: cakewalk pyro 5.0 serial
Cakewalk Pyro 2005 Plus 1.1 CWSP-5.00-834700-142248,
S/N: cwpp171331246 MP3 Creation Activation Key: 90F2A7FF Video DVD Burning Activation Code:: FCF9A2F9
or
CWSP-5.00-834701-451782,
CWSP-5.00-834702-106549( 3 serials
hope it helps
hope it helps
