Question about Miele Washing Machines
Miele w 3821 Machine beeping and showing F63
SOURCE: miele w3033 tech fault f63. what to do?
i have washing machine miele gala grande w 3000.and i have a tech fa ult f63.what is this?
Posted on Jul 03, 2010
SOURCE: hi,i have a washing machine miele w 3000 tech
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
Posted on Jul 16, 2010
  • 6277 Answers
SOURCE: Machine beeping and showing F63
Sorry but I do not know your particular machine and I do not have the cause of F63- not in my list-BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 14, 2011
  • 251 Answers
SOURCE: My Miele 1374 washing machine
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Posted on Jun 14, 2011
SOURCE: Miele fault F63
Just thought I'd add some feedback here which may help someone (March 2013). We have a Miele Novotronic W1613 washing machine which developed a "Technical Error F63". I contacted Miele, and they told me that this required a "PC download" to fix - basically, updating the software in the washing machine. If you look at the front of the W1613, just below the Start button is what looks like a little glass LED, labelled "PC". This is a fibre-optic link access to the washing machine's processor. Miele very kindly agreed to fix the machine free of charge (we were actually a few days out of the two-year warranty). The engineer used a suction cup to connect a fibre-optic link to his PC, and updated the machine's software. This solved the problem! Obviously, this is not the sort of problem that can be fixed by yourself...
Posted on Mar 18, 2013
How do I fix this myself: Miele Softronix W 1734. Reports Error: "F63" When I look up that error I get: "Contact Miele technician"
either the controller is not working or the inlet valve is bad .could also be the pressure switch that tells the machine when it is full enough
Jun 05, 2016 | Miele Washing Machines
Machine flashing f63 washing machine
If this is a Miele washer, open and close the door and press cancel and pause twice that should reset it.
Nov 07, 2012 | Washing Machines
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
Jun 05, 2011 | Miele W 4800 Front Load Washer
Hello, i'm facing the following issue technical default F63 on the W5794 washing machine thanks in advance for your precious help regards
Hi vianney_dupa,
Your water path control unit is not registered by the PC Board. This is the Pressure switch / Water Level Switch. I'd kindly suggest you get a qualified technician to come and check your machine. If not well diagnosed it may lead to further damaging the machine.
Sorry, no quick fix here - This is were Miele machines get complicated O.o..
No need to vote my answer, I'll understand.
May 12, 2011 | Miele Touchtronic W1213 Front Load Washer
John C
Mar 14, 2011 | Miele Washing Machines
Hi,i have a washing machine miele w 3000 tech fault f63.what i can do?
Total Cost: (HKD)
1100 for the part
Jul 03, 2010 | Miele Washing Machines
Miele w3033 tech fault f63. what to do?
Jul 04, 2009 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
