Question about Konica Minolta Bizhub 501 Copier
Error code C- 3502
Doesn't start
What is error code 3502
Sir/Mam,
The fusing unit is causing the error. that part that gets hot. The code is stating its getting to hot. When was the last time a Preventive maintenance was done every 250,000 copies certain parts are to be replaced. You can try reset power off (Main Power Sw is inside) Sub power is on the op panel try leaving the sub on then power on with main close door once on keep the utility button down) the machine hold the utility /counter button down power on the machine wait to you see trouble reset. touch it see OK then power off wait ten seconds power on. IF the code comes back do not reset again the machine is telling you its broke this section of the machine can get hot enough to burn!!!!!! Get a technician out to fix it and conduct a PM remember every 250K and replace drum 500K
Jun 30, 2014 | Konica Minolta Bizhub 600 750 Image...
Printout is light and fuzzy with Advent 10 after cleaning and testing
ERROR CODE 3502: is Paper Tray Empty
CODE 3829: Is not listed on the Advent web site. It may be printing head jammed.
https://adventprintersupport-en.custhelp.com/app/answers
Feb 11, 2014 | Computers & Internet
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
Dec 27, 2013 | Konica Minolta bizhub C450P Laser Printer
Entering code sc 542
Fuser error code press clear modes (yellow) 1 0 7 then hold down the stop key for 5 or so seconds screen will change, cycle power
Nov 23, 2013 | Gestetner Aficio 1035/g/p, 1045/g/p...
The copier doesnt work
That is a Fusing Error Code.
These can only be reset by entering into Service Mode. I do not recommend just resetting the code, as this code indicates that the fusing lamp remained on after the unit had fully warmed up. Just resetting this could lead to damage to the copier itself, or in an extreme case, a potential fire.
I'd get this machine looked at by a trained service provider, as it most likely is going to need parts replaced.
Oct 14, 2012 | Gestetner Aficio 1035/g/p, 1045/g/p...
Error code 3502
For all in one printer 3502 error code indicates that main paper tray is empty or the printer did not detect the paper., Make sure that the paper is properly inserted and paper tray is properly aligned. You can also try to clean the rollers of the printer on the fornt and at the back (Just remove first to rear access door of the printer for you to able to see the rollers at the back of the printer)
if you are using the 5000 series Printer press and hold copy and cancel to do the media sensor calibration
If this issue not solve call kodak toll free 1 800 421 6699 and send the printer for repair
Oct 10, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak printer will not print or photocopy and no i am not out of ink!!!!! it keeps flashing up Code 3502. i have paper in and there is no paper jam. What is the probem!!!!!!
This happened to my Kodak printer recently but I've got mine fixed. Firstly you must check that you do have ink and if so than update your driver by going on their website. I did this but the driver did not matter. Anyway if this doesn't work than you should contact them and they may ask you do go on a website where they can fix your kodak from a computer live on screen (they control your mouse). If they say it doesn't work they will compensate you with a free visit to check what has happend or they will refund you with the lattest printer and you only have to pay 30 pounds.
PCHELPSTER007 from youtube
Jun 25, 2011 | Kodak Office Equipment & Supplies
What do error codes 3501 and 3502 mean?
One of the best ways to prevent Printer error code "3501" from happening is to install latest version of firmware. To update firmware manually you can place the calibration sheet over the scanner and press START button. You can then click the HELP icon and select Maintenance option. From there, select Firmware Upgrade option and follow the instructions given there to download the latest firmware version; free of cost.
Nov 06, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
ERROR CODE 3502
Nov 08, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Konica Minolta Bizhub 501 Copier Logo
107 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
