Question about Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0
Port forwarding how do I port forward on and SB6141 Motorola Router?
How can i get belkin n300 to recognize motorola SB6141?
Well kindly reset the belkin N300, try connect, most probably will get connected....By the by, which mean are you going to connect both? is through lan cable or wifi?
Jul 26, 2014 | Belkin Surf N300 Wireless Router...
Comcast cable says they don't update firmware. l have a SB6141 motorola DOCSIS 3.00 and l just upgraded to 105 mbps. l'm hardwired to my modem. l'm only getting 32 power level ?
You may need to enable IPV6. All Comcast modem updates are done automatically. I would contact ARRIS for additional assistance. Comcast also has a helpful online community.
Mark
Motorola Mobility Support
Jun 18, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Need to open ports on my surfboard sb6141 to play on playstation3
surfboards are not routers... you need a router connected to your surfboard on the WAN port of your router. Then, port forward the ports you need to your play station.
Feb 28, 2014 | Computers & Internet
How do i open my nat for my motorola sbg900
for static IPs: check your router settings. router should be in "bridged" mode so that all the devices have own static "lan" ips like 192.168.0.1 / 192.168.0.255 router will have one lan ip static and one global ip(one it gets from service provider) you must manually give one address of 192.168.0.1 / 192.168.0.255 for your xbox. then give correct subnetmask (default 255.255.255.0) and gateway routers lan ip (default 192.168.0.254) you can aslo put routehrs lan ip as default dns if needed dmz or port forwarding is a tool in your router settings you can assign outside ports to specific ip i have only done manual port forwarding, not sure how dmz works.
Feb 26, 2011 | Arris SURFboard SBG900 Wireless Router...
How do I turn off wireless security?
  • Disable the fire wall by logging in to the administration interface of your router and looking for a firewall section. The administration interfaces differ depending on the manufacturer and model, so your wireless router might not have a firewall section. If it does, click on that section and turn off the firewall.
  • 2
    Forward a port. If the firewall is preventing an external computer from connecting to your internal client, you will need to forward a port to your client.
  • 3
    Find your internal IP address.
  • 4
    Click on "Start -> Run..." and enter "cmd" into the box. When the command-line pops up, enter "ipconfig" and hit "Enter." Find your IP address in the statistics that are printed out.
  • 5
    Refer to your software's documentation to find which port number must be forwarded.
  • 6
    Log in to your router's administration interface.
  • 7
    Click on "Port Forwarding" or an equivalently named section. The name of the section will differ depending on your router's manufacturer and model.
  • 8
    Add, on the correct port, a forward to your IP address. You will have to update this port forward in the future if your IP address changes. If your IP address changes often, ask your network administrator for a static IP address
  • Read more: How to Disable a Wireless Router Firewall ' eHow.com http://www.ehow.com/how_2091716_disable-wireless-router-firewall.html#ixzz14HV1mYNW
    Nov 04, 2010 | Arris SURFboard SBG900 Wireless Router...
    How do i accomplish port forwarding on a motorola sb5101
    motorola sb5101 is a modem. Modems don't offer any settings to change. you would have to forward ports on your router if you have one. Other wise you will have to open the ports through your current firewall.
    Jul 18, 2010 | Arris SURFboard SB5101 Cable Modem
    How do you port forward motorola sbv5220 modem
    there is nothing to forward this is a modem not a router
    Jul 10, 2009 | Motorola Computers & Internet
    Port Forward on Comcast Motorola SB5120
    Are you just using a modem and NO router? This modem has no NAT so there is no way to open ports.
    Jul 09, 2009 | Arris SURFboard SB5120 Modem
    Motorola SBG900 Port Problem
    plz check the firewall of the router as well.they tend to close the ports to avoid malicious attacks..try it..if it doesnt work,,keep me posted
    Apr 26, 2009 | Arris SURFboard SBG900 (49402201900) Modem
    Port Forwarding for Transmission
    This web page has a wonderful graphic step by step to use port forward for your linksys router:
    http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/default.htm
    Hope this helps.
    Mar 29, 2008 | Linksys Wireless-G WRT54G Router
    Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0 Logo
    148 people viewed this question
    Top Arris Computers & Internet Experts
    bobkoure
    Level 1 Expert
    Suddenlink Help
    Level 1 Expert
    Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
