Question about Denon AVR-1603 Receiver
Sudden hum in speakers connected to Denon AVR-1603
I came back from vacation to find that no matter what is playing on my receiver, there is a loud steady hum now coming from the speakers. I have disconnected everything to eliminate the chance it is due to a bad input ... no change. I have looked inside to see if there was an obvious burn-mark or popped capacitor or similar ... there are no visible problems. Everything else works. Do you have any suggestions? I am an electrical engineer, but I work with computers, not audio equipment. I am comfortable with technical talk and I can handle a soldering iron.
  • Jeff Wright
    Jeff Wright Aug 12, 2007
    I assume you mean "relays". I don't know what they look like, but send me the manual and point out where they are and how to test them. My email is [email protected]
    President:
  • 3,130 Answers
The hum is not the relays! It is a bad filter capacitor in the power supply. Go in the power supply, and with a multimeter, on the AC range, go and measure all of the main capacitor and see if you get a small AC voltage across it. If you do, replace it. The relay does nothing more then switch the speakers in and out of the circuit.
Posted on Aug 13, 2007
    Sergeant:
    Champion:
  • 326 Answers
Hello, please check/replace the relais. If you need more info please advice. Arpi
Posted on Aug 12, 2007
  • 1 more comment
  • Arpad Kothai
    Arpad Kothai Aug 12, 2007
    Hello again,
    if you leave your email I can send you the service manual.
    Best regards,
    Arpi
  • Arpad Kothai
    Arpad Kothai Aug 13, 2007
    the manual is sent by Pando.
    Best regards,
    Arpi
  • Arpad Kothai
    best way to check the relays is by replacing them. RLY 101-104, RLY105, RLY106 page 22 of the manual.
    Best regards,
    Arpi
SOURCE:
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
Quite front speakers
Check to see if there is a way to adjust the balance for the speakers or set individual volumes for each speaker.
Jan 30, 2014 | Denon AVR-1603 Receiver
We have a Denon AVR 1603 approx. 7 years old. Over the past few weeks, when we have been playing CD's the power clicks off. So we have to turn the system on again from our universal remote. Today,...
Any device has only so many self-protection cycles in it before it gives up the ghost.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 15, 2011 | Denon AVR-1603 Receiver
I will be watching either satellite or movies through my PS3 and the sound will suddenly go out. I"ll get a loud humming sound or static coming through the speakers. After i shut off the reciever...
hi,
may be there was some loose contact in ur receivers rear connections.thts why it produce the loud hum. use good quality inter connects. check is the all connectors are properly inserted or not.
ok
Dec 23, 2010 | Denon AVR-1508 Receiver
Hooked up the subwoofer and it doesnt work at all is the a subwoofer on and off button for this receiver
No, you have to follow the procedures in the manual to inform the unit that there is a subwoofer, then select some parameters on how it is used depending on the functional sizes of your other speakers.
http://www.retrevo.com/s/Denon-AVR-1603-Receivers-review-manual/id/363bh846/t/1-2/
Page 10
Aug 16, 2010 | Denon AVR-1603 Receiver
Two front channels don't work, speakers and wires
First of all please check the mode in which you are operating. Use the tester to see if there is tone on the speakers. Use a good DTS source and swtich over to 5.1 to check for requrired levels. If there is no sound yet, please open the cover and check for the connections to the front channels, check if the relay is clicking. You will have to look into the output mosfets for damage. for this the main board has to be accessed. If you think that you are not able to go deeper into find out the nearest Denon service centre. many such centres do not accept a set if tampered and so you need to be careful not to make it more costly. Hope my advice helps. Good day
Jul 06, 2010 | Denon AVR-1603 Receiver
Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Nov 26, 2008 | Denon AVR-1603 Receiver
AVR-1603 - no Sound exept over Headphones is a weak signal
First check the outputs at the output fets/transistors for any DC voltage. Reference your voltmeter to the speaker - terminal. If there is ANY DC offset, the amp is shutting down the outputs to protect your speakers from DC. Is the power supply + and - 47 volts? If only one supply is there That is your problem because the supplies should be symmetrical. Also look for any wiring problems from the amp to your speakers... any shorts? Try disconnecting all your speakers to totally eliminate any speaker problem and see if the relays still click. You should hear only ONE click when you first turn the amp on (delay of about 2-5 seconds). If they keep clicking the amp outputs are next. Also, is there any indication on the front panel of what is failing?
Jul 29, 2007 | Denon AVR-1603 Receiver
Denon AVR-1603 Receiver Logo
340 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
