Brother lc51 my printer wont print anything other than blank paper why??
SOURCE: blank paper
Turn printer off. Hold down big blue button and turn the printer back on (keep holding down big blue button). After a couple of seconds a test page will print (not the demo page). This solved my problem, hopefully it will help you as well.
Posted on Aug 20, 2008
Ajkill
  • 2035 Answers
SOURCE: brother laser printer wont print
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Posted on Feb 09, 2009
SOURCE: saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Posted on Feb 12, 2009
rscheutz
  • 54 Answers
SOURCE: won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Posted on Mar 25, 2009
SOURCE: Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Posted on Apr 23, 2010
The black cartridge (Brother LC51) doesn't print on my Brother MFC 685CW. The other 3 cartridges print just fine and passed the Print Quality Check. Running clean cycle doesn't help
In order to print in Black and White using grayscale, you will need to adjust the printing preferences within the driver. To change the printer properties complete the following steps:
1. Open the Printers Folder:
  • Windows 2000: Click Start => Settings => Printers.
  • Windows XP: Click Start => Printers and Faxes.
  • Windows Vista: Click the Start button => Control Panel => Hardware and Sound => Printers.
  • Windows 7: Click the Start button => Devices and Printers.
2. Right click on the Brother printer driver and left click Printing Preferences.
3. Click the Advanced tab.
4. Select Grayscale.
5. Click APPLY => OK. Your printer will now print in grayscale.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | Brother MFC-685cw InkJet Printer
I can not get it to print anything but blank psges
hi
if your printer taking papers it mean your printer is working fine chack your cartrege
clean your cartgerges
Jun 03, 2010 | Brother MFC-5890CN All-In-One InkJet...
Prints only blank pages
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Regards
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
A manual for the brothers series lc51 mfc ?
LC51 IS THE INK. GO TO BROTHER.COM AND DOWN LOAD THE MANUAL, BROTHER SR TECH GOOD LUCK
Feb 02, 2009 | Office Equipment & Supplies
Prints on copier not from pc
Try updating the driver, it should be available from Brother's website.
Sep 20, 2008 | Brother DCP-330C All-In-One InkJet Printer
Blank paper
Make sure you are letting it warm up long enough.
Brother HL-2140 Support
Jun 16, 2008 | Brother HL 2140 Laser Printer
Brother MFC 5460CN Won't Print w/ Full Black Cartridge
What type of machine do you run?!! MFC420 or mfc 5460?!!
Is it a machine with LC51 or LC41 carts?
In both way: Did you check the other carts? It could be that there is another one empty.
Did you stick the tape at the right place, too? The tape should be a bit larger than shown on the pic.
For the LC51 it it the same position.
Did you answer the printers question of changing the cart with YES?
Nov 27, 2007 | Brother MFC 420CN All-In-One InkJet...
jasbo
jasbo
