Question about Ruud UAMB Air Conditioner
036jaz reset button located - Ruud UAMB Air Conditioner
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
Wiring diagram RUUD UAPA-036JAZ
the condensor gets 240 volts a-c and 24 volts a-c to control contactor. pretty straight forward on this 3 ton unit. the 240 volts comes off breaker box and the 24 volts comes off thermostat and common of transformer.
Jun 10, 2014 | Ruud Heating & Cooling
Exterior fan motor replacement
i would replace its run capacitor first.
Jul 04, 2013 | Ruud UAMB Air Conditioner
Rheem condenser fan don't spin up under it'sown power.
If you have a multimeter that tests "uf" or "mfd" that is microfarads. That will test the capacitor. Turn off power to unit, touch top of cap with insulated screwdriver across terminals to discharge and remove fan and common. MARK WHICH WIRES GO WHERE. Or if no mfds on multimeter, amps×2650÷volts=mfd. Amp draw on fan wire off of cap times 2650 divided by the volts between common and fan on the cap. If cap is good it's likely the motor.
Apr 12, 2017 | Heating & Cooling
RUUD uaka-036jaz not cooling, outside fan does not turn on but air handler (in attic) runs and circulates hot air - how to fix and/or reset?
Check your disconnect or breaker that is located close to the outside unit. Next you need to check the contactor in the outside unit. Set the thermostat to make the air come on then check the contactor. It should be pulled in closing the contacts. If it isn't the problem could be the contactor or thermostat. Next check the voltage on the load side with it pulled in. If that's good then check the capacitor. If it looks swollen, it's bad. You can also use a multimeter with the capacitor check function to do this. Let me know what you find.
Sep 27, 2010 | Ruud UBHC Air Conditioner
My ruud upka-036jaz keeps freezing
First off check your air filters and make sure the indoor fan is running. If there is not enough air flow over the coil it will cause this. If those are OK you may have a low refrigerant charge.
May 02, 2010 | Ruud Heating & Cooling
Ruud UAMB Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
