Question about RCA P52921 52" Rear Projection Television
SET TRIES TO TURN, BUT DOESN'T
My RCA P52920BL 52" projection doen't turn on. For a couple of days the set would turn, and I would see an arc on the screen. Next the tv would turn on, but after a minute it would shut off for a couple of seconds then turn on. The set would do this 4 or 5 times then stay on. Then it wouldn't turn on at all. I can here it trying to turn on through the speakers, but it doesn't. I am a tech, and know the problem is in the power supply, but don't have a service manual... Henry
  • 6 more comments
  • Henry Adams Aug 25, 2007
    I paid for your premium service for my tv problem. When can I expect a solution? Henry
    I have a very limited schematic for my tv..Where is it located, and if possible part number? Does this solution addresses the problem of the tv trying to start a couple of times, and then shutting down?
    Henry
  • Henry Adams Aug 31, 2007
    Hey Mike...I understand that the problem may be in the Flyback Transformer, but like I said I have a very limited schematic. I can't locate the part I need to check...It's like being dropped in the middle of a rainforest, and asked to find my way home...Is this transformer on the main board? If you could give me a part number I may be able to find it, with what I have to work with...Thanks.....Henry
  • Henry Adams Sep 02, 2007
    Thank You Mike for getting back to me...Like I stated I am a Tech, but not so much on tv's. I have with your help located the flyback transformer. I am just going to go ahead and replace it, and see what happens....Let you know.....Henry
  • Henry Adams Sep 03, 2007
    I replaced the flyback transformer from a tv like mine..The tv turns on with audio, but no video. I guess I'm getting closer, because the set turns on. Any idea's on the video? Henry
  • Henry Adams Sep 08, 2007
    As I stated I replaced the flyback with a used one. The sound came on, but the video didn't...Had nothing to do with the screen adjustment. I've since replaced the flyback with a new one..Now the symptom is no sound or picture, but the focus part of the guns glow in turn in the plastic part of the guns. The tv then turns off. Maybe some other short somewhere caused the transformer to go...Any suggestions? Henry
  • Henry Adams Sep 15, 2007
    Here's a little comment for you Mike. To test for a shorted flyback transformer. First you disconnect the screen and focus leads, and place them where they can't touch something. Turn on the set and see if they are energized. If they are it's not the transformer. Then connect the screen lead and turn on the set, if it turns on that's good. Connect the focus lead and if the set turns off the focus module is most likely bad. The advice you gave me sent me on a wild goose chase....As it turns out the focus module was bad, and the transformer that I replaced for $68.00 was good. The set is up and running now no thanks to you. Next time don't act like you know it all.....Henry
  • Henry Adams Sep 16, 2007
    If you knew what you were doing as a tech with your experience you should have known that the white high voltage block in the RCA very rarely goes bad. Don't worry about, being the bad tech that I am I figured it out all by myself...The set works perfectly. If I hurt your ego I'm sorry, but that's the way it goes.....Henry
  • 398 Answers
The RCA P52920BL uses the PTK195 series chassis. The most common reason for the set not turning on is a shorted flyback transformer. To check this, measure the B+ when the set is plugged in - it should be around 145 volts. When you turn the set on, see if the B+ drops down at all. If the flyback is shorted, the set will try to start but the flyback draws too much current. The microprocessor senses this and immediately shuts the set back off. To confirm, unsolder the jumper wire bringing B+ to the flyback and put a 100 Watt bulb in its place. Turn the set on and if the flyback is shorted, the set will now stay on but the bulb will glow as bright as if it was plugged into the wall. If this is the case, replace the flyback. Let me know what you find and we will take it from there.
Posted on Aug 25, 2007
  • 2 more comments
  • Mike Longo
    Mike Longo Sep 01, 2007
    Well, the flyback is the transformer with the thick red wire coming out of the top. It is right along the back of the main board, and has the 2 controls labeled FOCUS and SCREEN on it. If you do not know what a flyback is, you really should not be messing around inside a projection set. I strongly suggest allowing a qualified tech to check it for you.
  • Mike Longo
    Mike Longo Sep 02, 2007
    Good luck, and remember that when the new flyback comes, the screen and focus controls will be set to minimum. The screen is the overall brightness of the picture and the focus is the sharpness.
  • Mike Longo
    Mike Longo Sep 03, 2007
    As I said, the flyback comes with the 2 controls set to minimum. They are labeled SCREEN (on the bottom) and FOCUS (on the top). Turn the set on and tune to an active channel. Turn the SCREEN control up (clockwise) until you see a picture. Turn the FOCUS control up until the picture is nice and sharp. Go into the menu and set the brightness and contrast to minimum, and readjust the SCREEN until the picture is just barely visible. Put the contrast and brightness controls back to normal and your picture should be nice and normal. Tune in a channel with white letters on the screen and touch up the FOCUS, making the white letters nice and sharp. Let me know how it turns out.
  • Mike Longo
    Mike Longo Sep 15, 2007
    Here is a little comment for YOU, Henry. The screen and focus leads have NOTHING to do with testing a flyback! The focus and screen wires can be completely shorted to ground in a standard TV and the flyback will still run. In the PTK195 chass, the flyback doesnt even HAVE a screen or focus wire! The 3 screen and focus wires originate in the focus block. The high voltage wire is the only one that matters, and it connects to the high voltage splitter, not a "focus module". When you stated you are a tech, I assumed that you would have had the common sense to test the high voltage splitter first. That is as basic as putting a new light bulb in a lamp that will not light up. When you stated that you were unable to locate the flyback, you were basically stating that you should be nowhere near the insides of a projection set, and I did not want to assist you. But you insisted, so I offered advice. On Sep. 3, you stated that the "new" flyback was working and you then had audio. That statement implies that the high voltage splitter is good. I assumed you correctly installed the flyback and correctly reattached the high voltage lead. The statements you made were misleading because YOU failed to install the flyback correctly! I cannot understand why people like you who have absolutely no experience in this field assume you are qualified to service your own set. I have been testing and replacing flyback transformers and high voltage splitters for over 25 years and you have NEVER tested or replaced one. You sent yourself on a wild goose chase by providing the wrong information! Next time, do not say you are a tech and try to provide more accurate information.
RCA 52" rear projection tv
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | RCA P52920BL 52" Rear Projection...
RCA 52" projection P52920BL no volume, if you turn it up can hear speaking chirping
check the back of set to see if there' an internal external speaker switch- also check on screen audio menu to see if speakers are set to off
Oct 18, 2009 | RCA P52920BL 52" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
MY RCA 52 IN TV WONT TURN ON?
MOST LIKELY, THE PROBLEM
IS THE BULB USED IN THE SET?
BY THAT I MEAN THE HIGH INTENSITY REAR PROJECTOR BULB?
DO A SEARCH ONLINE AND THERE ARE COMPANIES SELLING THE BULBS AT A PREMIUM. YOU MAY WANT TO CONSIDER DUMPING IT.........
Mar 14, 2009 | RCA P52920BL 52" Rear Projection...
No Power to Model # P52920BL
Sounds like the flyback transformer and horz output,the output shorts and the set will just tick when its pluged in to the ac
Dec 30, 2007 | RCA P52920BL 52" Rear Projection...
RCA P52920BL
F32 or F36650 = same transformer = 257805 or Asti 2078
P52920BL = need service number = P52920BLXXX then I will
confirm flyback part #..................................T.
Dec 26, 2007 | RCA F36650 36" TV
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
Problem with RCA 52 inch
The flyback has burned a hole in the side,it needs replacing
Dec 03, 2006 | RCA P52920BL 52" Rear Projection...
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA P52921 52" Rear Projection Television Logo
197 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
