Question about Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009
Kenmore 253.9133580 freezer wiring diagram
Where can I get a wiring diagram
Kenmore upright freezer does not shut off until door is opened. freezer seems to work well.
Going by the service manual it seems that everything is fine. The fan is supposed to run while the door is shut and the compressor is supposed to run 12 hours and then a 30 min defrost cycle comes on then the cycle starts over again. I am posting the service manual, parts and wiring diagram for you to view if you so choose. https://files.acrobat.com/a/preview/8a6d6ca4-04b6-4cfa-b435-3980042b3ad3
https://files.acrobat.com/a/preview/6d7f8a46-0daf-4e01-aa54-01f306301f31
https://files.acrobat.com/a/preview/12246a57-0a63-4d66-b3f3-7f7b67536da6
May 31, 2016 | Kenmore Freezers
Need wire schematics for a old Kenmore upright freezer Model #22138
need the entire model number from the tag on the unit
Mar 08, 2015 | Kenmore Freezers
My kenmore mod#2539183511 chest freezer comes on @30 sec goes off for @3-5 sec tries again.Need diag help or wiring diagram.
Sorry to read about your problem. you can have many different problems.
a wiring diagram will not help you in this case. all 3 items below at at the compressor.
odds are you will have to have the compressor replaced.
1. Failing compressor
2. Defective start cap
3. Defective overload protector
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Jan 02, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
I need to replace the thermostat on my very old Kenmore Coldspot Upright Freezer, model 106628420. I have no owners manual and there is not one to be found. I would like any help possible. Thank you so...
Not that this diagram is a lot of help, but I did find this on a Sears website:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Freezer-Parts/Model-106628420/0582/0142000?sid=PDVertical
Nov 10, 2010 | Kenmore Freezers
The freezer has been beeping about every 30 seconds for the past few years and I am going crazy. How can I fix it?
along as the freezer is workin fine then you can do this:
sorry if i am not accurate but you did not provide a complete model number so i dont have any diagram to follow
if this was my freezer and i would disconnect the wires going to the beeping sound. i thought of that too of course. if you send me a complete mod. # then i will give detail way to do this
hope this was helpful
Apr 02, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Not working like it dead
Go to sears.com and use the parts link and enter your complete model number. it will take you to the specs. and diagram.
this problem could be one of several so i am going to list the possibilities:
freezer is stuck in defrost mode (the timer will do that so it could be the timer)
thermostat not working
as far as this these two parts control operation
i would start 1st with the t'sat. unplug then get to the t'sat take off the 2 wires and jump out those 2 wires (put the 2 wire together somehow but be careful)
make sure the wires dont touch anything (especially you when you plug in)
if the freezer kicks on replace t'stat
if it doesnt them replace timer
Mar 11, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Chest Freezer Wiring
hi mel,
green with yellow are ground wires and usually are from compressor to system chassis from your 3 prong plug use the green wire and just find a point on the chassis to pin to if you can get model number you can find on kenmore website
May 01, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009 Logo
26 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
