Question about Garden
PTO will not stay engaged
2006 Troy-bilt Super Bronco Riding Mower.(60TG). First time using this mower.Starts and runs fine. Cutting blades will only stay working if you continue holding PTO lever forward in the engaged position. If you let go of the PTO lever it returns to a neutral position and blades quit , but mower remains running.
  • 62 Answers
SOURCE: Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Posted on Sep 07, 2009
mowerman1857
  • 389 Answers
SOURCE: PTO will not engage blades on riding mower. The
Using a test light or volt meter, check to see if you are getting a full 12 volts at the connector where the PTO plugs in. If no voltage present, locate the fuse for the PTO and check it, also check the PTO switch to see if it is working. You can turn on the ignition switch to the run position, don't start the engine, and turn the PTO switch on and off several times listening for a clicking sound. If you hear it clicking, have someone sit in the seat and start up the engine, while it is running, observe the PTO clutch and see if it spins when turned on and if the belt turns with it. If none of this works, post a follow up and include your Craftsman Model number. I will look it up and see if I can find anything else we might be missing
Posted on Sep 21, 2009
cardenderek
  • 783 Answers
SOURCE: I own a 42" Troy Bilt zero turn. The PTO switch
What the problem is (im not sure if they are called this) but the deck pulley brakes are worn out.
Basically if you look under the rider frame side (on top of the deck). There are on each side for each spindle pulley a flat metal tab. On the underside of that is just like a brake on your car. So when you raise the deck the pulley brakes hit the top of the pulleys and stop them from spinning. Which cause the blades to stop spinnign. There are probably turning at 10% of there normal speed. If that sound like what its doing check the brakes.
They are a replaceable part. Sorry I just cant remember exactly what they are called. Over the years they just wear out like a set of brake pads on your car. And the mower cuts and just work fine. Thats where I would start. When they wear out, the friction material is gone. Best Reguards, Premium FixYa Support
Posted on Jul 27, 2011
  • 6468 Answers
SOURCE: blades wont work on 2004 troy built riding mower
check the belt tension if it has a switch to turn it on check the fuses and see if theres power going to the clutch
Posted on May 20, 2012
waynepwelker
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
I have a troy Bilt riding mower and When we turn pto on to engage it will engage but the noise is so loud. And the pto will not stay in the on position.
check and look at deck [ unit not running and key in pocket ] for loose ,damaged ,debris or out of alignment==belt ,pulley , mandrel,tention/actuator pulley or blades
May 04, 2017 | Troy Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Jun 27, 2012 | Troy Garden
Troy Bilt model 60TG I hit a small piece of wood and the tractor
If you haven't already, check to see if there is a hunk of wood wedged between the blade(s) and mower deck. I've seen that happen. I pried the hunk of wood out with a crowbar and life was good again. The second time, someone ran over a campfire log they didn't see under leaves last fall and bent the blade spindle. It basically froze the spindle in place even though there wasn't anything wedged in there. I removed the belt from the top of the mower deck and then it started just fine..... although the blades and shaft were toast and had to be replaced. If you can disengage the mower deck without removing the belt(s), try it if you haven't already. See if it starts that way. If not, the issue may be more serious such as a broken connecting rod in the engine. Try the simple stuff above first to troubleshoot the cause.
Apr 30, 2010 | Garden
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
