Question about Canon PIXMA MP780 All-In-One InkJet Printer
##343 hi my printer is not working and there is acod ##343 . can you please tell me what's that code mean, and how can I fix the machine. thankyou best regard maan
    Brigadier General:
  • 6,966 Answers
Hi, If memory serves me right, this indicates that the waste ink absorbent material is full. They are considered consumables and therefore are to be replace after some time as in your case since they are full. You can do it yourself buy it's a messy job and you have to buy the spongelike wasteink absorber. It may be better to seek the services of a qualified professional or the Canon service. Hope this be of some help to you. Good luck.
Posted on Aug 12, 2007
SOURCE:
Canon MP36 error ##343
The error code means "Ink Detection Waste Ink Tank Full". This means that the ink pad needs to be replaced. Also, dont forget to set the eepron counter to 0. Please follow the steps:
Press
ADITIONAL FUNCTIONS
SCAN
COPY
SCAN
scroll to TESTMODE
scroll to PRINTER TEST
scroll to EEPROM CLEAR
and the press the numeric key 3 or and keys.
Select INK COUNT, and then press the
numeric key 0 or and keys to reset the waste ink capacity.
Press the [Stop/Reset] key and then the
[ON/OFF] key to end the test mode.
I tries to replicate this error in my printer and I was able to aolve it with the above mentioned steps.
Hope this helps!
Rehards,
HP
Aug 28, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Unable to get Printer cartridges to work on HP6313
Model names in the HP Brands can sometimes be similar and confusing because of the prefix or series attached to them.
Consult your manual for the required toner cartridges
When purchasing the replacement, go along with the finsihed set in order to help you identify them at the shop
Also you can try the HP 343 or 348 Tri Color, HP 339, 336, 337 Hi capacity black
Honestly i would advise taking the finished set of toner cartridge to the store and purchase the same model.
Laslty take out the toner and look behind it or at the side. Theres a unique code or number inscribed on it. that would help you to get the toners that are compatible with your printer
May 21, 2009 | HP Office Equipment & Supplies
Can not print media
Basically ##343 means the waste ink absorber needs replacing (soaks the spilt ink up under the cartridges).
http://www.tradebit.com/filedetail.php/3901083-canon-pixma-mp780-service-manual
Link to an official Canon service manual. That should tell you how to change it.
Nov 07, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Error code 9-343
all 9-xxx codes are xerographic problems,such as toner,drum,developer or auto density.install or replace one or the other.
Jun 30, 2008 | Xerox DocuColor 12 Color Copier
Error code 9-343 for Ducocolor 12
That is a contact failure on the BTR roller. It is the larger black roller inside the left side door. It may just have a dirty contact, or may need to be replaced. But for some reason the machine is not seeing good contact to that roller.
Mar 21, 2008 | Xerox DocuColor 12 Printer
CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
Feb 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Error code E 5
This means that the ink cartridge may not be compatible or may not be installed correctly. It also may just be an issue with the printer itsel on lower end models.
Oct 16, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Error code ##343
We have just attempted to install an Cannon imageclass mp360 and the error message "check printer ##343" is displayed.
Can you please help.
May 14, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
144 people viewed this question
Clive
Clive
old marine
old marine
Ekse
